APT Holman Amplifier 1Opinion
snow
snow Posts: 4,358
Hi everyone I would like to hear thoughts on the APT Holman Amplifier 1 from those who have either listened to one or have owned one. Either negative or positive both are desired. I have owned the APT Holman preamp before and just purchased another and am now looking to purchase an amp or amps but hate to spend the money if they are not worth the expense so am looking for opinions before I bite the bullet.
Regards Snow
  • snow
    snow Posts: 4,358
    Wow crickets. I suppose I will just have to take the plunge buy one and listen for myself, I know they are scarce none for sale except for one on CL in Massachusetts and a pair plus the preamp on Ebay untested other then to power on and from looking at the packing job does not inspire confidence. There is a fellow on Audiokarma that says he has a pair that he would sell for $845.00 each plus shipping and PayPal fees once he has restored them but no reply back as of yet.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,323
    edited February 2025
    One of the great things about the APT Corporation was their service manuals, they are by a wide margin the most informative sources of general audio information ever. They explain the overall concept of the device, how to measure any of its parameters, including suggestions of what specific test gear to use and what to look for while testing. The manual explains that the amplifier uses a differential input, no capacitors in the audio path, a well thought out power supply, careful attention to making sure the performance is maintained with any speaker load and plenty of protection. While it's hard to judge how something sounds based on looking at the schematic and reading the service manual it does give an insight on what the designer felt was important and from that standpoint the APT should be a winner.
    With that said, I can also endorse the British made Quad 405 amplifier, the Audio Research D100.2, the McCormack amp and the conrad johnson solid state amps.
  • snow
    snow Posts: 4,358
    Thanks Ken I like Quad gear and of course Audio Research Conrad Johnson made some fine gear. I suppose the APT stuff is rare enough that most have not heard anything so cant comment one way or the other. I have owned the preamp before and sold it and have regretted it every since. The reviews I have read seem to be either very positive or negative on the amps, the overwhelming majority seems to be positive. I went ahead and bought one of the fellows amps today for $845.00 pus shipping and paypal fees from Peter at Quirk Audio it should be ready sometime next month and I will post my thoughts on it after I listen to it for a few days and compare it to other gear I have at home.
    Regards Snow
  • snow
    snow Posts: 4,358
    edited April 2025
    Ok I received the APT Holman amp 1 today and I am impressed by it's clarity and effortless power no matter the load. It remind me of a Sunfire 300 x 2 I own. I highly reccomend Peter at Quirk audio for restoring this and I am going to likely buy a second one from him so I can run them in mono bridged mode. The amp seems to sound significantly better after 15-20 minutes of playing it really comes into it's own very impressive which for me is saying something considering I have owned and listened to hundreds of different amps over the years.
    Post edited by snow on
  • Russ4Audio
    Russ4Audio Posts: 1
    Just a small quibble, tell me where to go if you like. The pre-amp was the Apt-Holman the power amp was the Apt 1 (No "Holman"). Kind of like "in the know" Mercedes owners always call them Benzes. Anyway, I bought my combo in 1982 and used them exclusively well into the 21st century. Loved them both and the versatility of the pre-amp was unmatched in its day, probably still is. The only issue I ever had was the mute circuit. It served several functions, it delayed output after turn on to avoid pops and it detected line voltage irregularities and would mute output if they went out of bounds. At some point it started to get finicky and eventually would not come out of mute. The power amp never gave the slightest trouble and after the Holman stopped working I used a cheaper pre-amp to run it for several years after. I have a much more modern (and expensive) setup these days but I will always remember the Apt combo as some of the best gear I ever owned.
