Receiver for polk audio set up
Answers
    billbillw Posts: 7,907
    Looks like you are figuring things out quite nicely!
  • davineC
    davineC Posts: 21
    Yeah I'm making progress lol
    Clipdat Posts: 13,100
    edited April 2025
    davineC wrote: »
    [/img]
    So on one channel we're using the gold as positive, silver as negative, and on the other it's reversed? That's not confusing at all.
    Then we got dual blue wires with seemingly no polarity markings for the surrounds/bookies. Interesting.
    I guess technically it doesn't matter if the polarity is reversed, they'll still make sound, but meh. Would be nice to correctly do it positive to positive, negative to negative.
  • davineC
    davineC Posts: 21
    edited April 2025
    Thank you steve just tried the tape trick and it worked, that's been bugging me for a while!
    It's sounding good so far, will probably irder the blue tooth adapter to make it easier m.
  • davineC
    davineC Posts: 21
    edited April 2025
    Thanks for pointing that out clip... my eyes aren't the best.
    With the blues I did try them each way to see where the sound was clear I noticed if they backwards it's somewhat muffled. I'm not knowledgeable on this stuff so not to sure about the technical aspect or "polarity" reference. Sorry 🤷🏻‍♀️
    edited April 2025
    It just means that on both the back of the receiver and the rear of the speakers, to connect red (positive) to red, black (negative) to black. But it's tricky when the wires aren't clearly labeled, as in this case.
    It sounds like you already experimented though and got everything connected properly now. Also no need to apologize, this stuff is difficult to explain in text over the internet.
  • davineC
    davineC Posts: 21
    Ok gotcha, thanks! 😊
    Tony M Posts: 11,804
    edited April 2025
    When somebody wires one speaker's polarity backwards, like I have twice in my 67 years, the bass loses sound pressure waves in a room.
    This guy explains the reason simply and clearly. Having the Correct Polarity for all speaker wire runs matters. B)
    https://youtu.be/eEBG442fX2E
  • davineC
    davineC Posts: 21
    Thanks for the vids, I was looking at the other ones and then they disappeared but I will look into it on YouTube. For now they sound good but I'm going to swap the red & silver around to see if I get a difference since i seen in the pic you sent it said silver to red. I just figured red to red. Most of the bass comes from the S15.
    F1nut Posts: 52,062
    This isn't hard. Connect the + from the receiver to the + on the speaker. After that it'll should be obvious where the other speaker cable goes. It doesn't matter what the color of the cable is as long as it's + to + and - to -.
    I see the videos were removed for some reason. :#
    This picture shows how simple wirig is too.
    https://www.manualslib.com/manual/115498/Onkyo-Tx-Sr500.html?page=13#manual
    I forgot to add, look on Facebook marketplace and craigs list for FREE receivers or affordable ones.
    Of course be careful!
  • davineC
    davineC Posts: 21
    Dang didn't think of that, I just picked one up at goodwill for $12 yesterday, now I have to figure this one out lol. .ujdskyh668xm.jpeg
    edited April 2025
    Yamaha's are easy and straight forward. VERY easy learning curve. I Love them.
    Look online for the Yamaha HTR-6230 owners' manual that you can look at. IT'S EASY if you read from start to end how this receiver's FUNCTIONS work.
    Heck, here you go...
    https://www.manualslib.com/manual/396936/Yamaha-Htr-6230-Av-Receiver.html
    Do you have good speaker wire to work with now? If not, get you some. B)
