SB-1 Subwoofer (Only) Hookup to Amp
I bought a solo SB-1 subwoofer, no soundbar, used. I'm trying to connect it to the preamp RCA subwoofer output of my AV receiver. So far, trying an RCA converter to either a stereo or mono 3.5mm plug does not work in the subwoofer's input jack. The plug fits, but when powered up it makes no sound.
I have another subwoofer that works when hooked up this way.
Any ideas for using the SB-1's input jack? (I can't connect it via wi-fi.)
Best Answer
Answers
    F1nut Posts: 51,766
    It connects to the Polk Soundbar wirelessly. It won't work any other way.
    The system also requires high-speed Internet, Wi-Fi router and an Apple or Android smartphone or tablet.
  • goofyroo
    goofyroo Posts: 3
    Thank you.
    It has a jack labeled "Sub Input." I'm trying to use it.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,308
    Hello,
    Welcome to the Polk forum. Let me check with a product specialist at Polk for you. I'll probably get a response on Monday, hang in there.
  • SeleniumFalcon
    I heard back from Polk and yes, that should be a functioning line level input.
    F1nut Posts: 51,766
    Interesting as that is not what the Net says.
  • skipshot12
    skipshot12 Posts: 1,959
    You believe everything you hear/read from the inter web? 😂
    F1nut Posts: 51,766
    skipshot12 wrote: »
    Appeared to be official Polk info.
  • goofyroo
    goofyroo Posts: 3
    edited April 2025
    Thank you, Selenium Falcon. Thanks also to whoever helped you.
    The input jack doesn't seem to work whether I use a mono or stereo 3.5mm. (I do get lights when I power the amp, and the same wire hookup does work on an existing subwoofer.)
    Could the Polk jack require something different from a mono/stereo 3.5mm?
  • skipshot12
    skipshot12 wrote: »
    Was just giving you the business…
    F1nut Posts: 51,766
    skipshot12 wrote: »
    skipshot12 wrote: »
    I know.
  • SeleniumFalcon
    I'm not sure, I'll ask what is required.
