Vincent Audio SV-500
Anybody here have hands on and ears on experience with this Vincent Audio SV-500? Looks like a pretty good deal right?
Thanks,
Eric
    gudnoyez Posts: 8,223
    I like my Vincent SA-T1 preamp and my Pho-700 phono amp. I've heard Vincent's bigger Integrated. Vincent makes good gear. I havent heard the one your looking at, but can only Imagine it's a decent little Integrated.
  • Conradicles
    Conradicles Posts: 6,435
    Well I did it and it's burning in now...
  • Conradicles
  • Unknown
    edited April 2024
  • PSOVLSK
    PSOVLSK Posts: 5,452
    LOVE my Vincent SV 226mkii…though I’m probably going to be selling it soon to help fund an upgrade. Vincent stuff looks great, sounds great, and punches above its class…IMO or course.
  • Conradicles
    This might be a keeper for me.
    edited April 2024
    Glad to hear your enjoying your Vincent, nice integrated you got there.
  • Conradicles
    edited May 2024
    Really digging this as hours get put on it. The packaging is amazing. Triple boxed with very high quality inner packaging. The remote is metal and heavy. Still got many hours before it fully burns in, but I really like it. Just installed some IsoAcoustic pucks under the feet.
    heiney9 Posts: 25,714
    I am looking at this to run in a 2ch living room rig utilizing the digital input hooked to the TV. I'll be doing occasional streaming (Qobuz), but mostly for watching TV.
    How is it working out? Roll any tubes?
  • pearsall001
    pearsall001 Posts: 5,400
    heiney9 wrote: »
    If I'm not mistaken I think the tubes in Vincent gear are permanent. I could be wrong though.
  • Unknown
    edited August 2024
  • PSOVLSK
    I had the Vincent SV-236 and LOVED it. I only changed the tubes in the last 3-6 months of ownership because I had one go bad. Wish I had changed them before then because it made a positive difference.
  • Conradicles
    heiney9 wrote: »
    No tube rolling yet. I still got all kinds of gear breaking in. New speakers, cables, streamer etc. I'm a Vincent fan now.
  • Conradicles
  • Conradicles
    edited March 2025
    Now I'm ready for some tube rolling.
    Suggestions? Looking for warmish'
    1 x 12AX7
    2 x 6N1
  • Unknown
    edited March 2025
  • Conradicles
    edited March 2025
    I "think" 6N1P Russian
  • Unknown
    edited March 2025
  • haudevbe
    haudevbe Posts: 17
    The Vincent Audio SV-500 is a pretty sweet hybrid integrated amp! You get that tube warmth in the preamp stage (dual 12AX7 tubes) while keeping the solid-state power section for better control over speakers. It’s a great way to add some richness and depth without going full tube amp.
    Pros:
    ✅ Hybrid Design – Smooth, warm mids from tubes + solid-state reliability
    ✅ Good Power – 50W per channel (8Ω), solid for most bookshelf and small floorstanders
    ✅ Multiple Inputs – RCA, digital coax/optical, plus a pre-out for subwoofer or external amp
    ✅ Great for Mids & Vocals – That tube glow adds some magic to vocals and acoustic instruments
    ✅ Solid Build – Typical Vincent build quality—clean, minimalist, and heavy-duty
    Potential Downsides:
    ⚠️ Not a power monster – If you have power-hungry speakers (like Magnepans or inefficient floorstanders), you might want something beefier.
    ⚠️ Stock tubes may need rolling – Some users swap out the stock 12AX7s for better NOS tubes (Mullard, Telefunken, or Gold Lion).
    If you're after that tube-infused warmth without losing control in the low end, it's a solid deal. Do you have specific speakers in mind for pairing?
