Budget System-Cambridge or AMC
heiney9
heiney9 Posts: 25,408
edited March 2005 in Electronics
Ok, so I have the bug to get a 2nd system for my office/computer room. I’m going to be adding a sound card w/ a digital out to my computer. I just purchased an AMC Dac8 digital to analog converter. So that is piece #1 of this ultra budget system that should sound pretty decent when I get done. I am seriously considering the Athena AS-B1 speakers. My compter will be the transport playing FLAC files and regular cd's.
I haven’t decided on what to power them with. I’ve narrowed it down to a few pieces. Keep in mind this ultra budget. I’m considering Cambridge Audio integrated specifically the new Azur 340A which I can buy new at Audio Advisor for $249. A bit more than I really wanted to spend. Or AMC like the 3100A or 3020 integrated’s. I feel the Cambridge would out perform especially the AMC 3020, but is it worth the cost difference for this system? I see the AMC’s on e-pay/Audiogon for $129-199. Are the AMC’s reliable? At $129 vs $249 it’s a no brainer I’d get the AMC. But I want this to be something that will last and sound decent and I’m just not sure of the AMC.
BTW I got my AMC Dac8 for $75 so that’s a bargain I can live with even if the quality isn’t what I expect, but they seem have a pretty good reputation.
In the speaker forum I’d asked about impressions of the Athena AS-B1, anyone own them? How are they?
Any comments/suggestions appreciated
Heiney9
Post edited by heiney9 on
  • hoosier21
    hoosier21 Posts: 4,415
    edited March 2005
    AMC is pretty solid gear, have no worries about that.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2005
    Yeah, what he said.
    AMC = great gear, any way you care to slice it.
    Cheers,
    Russ
