Powder coat or not?
muncybob
Looking at installing railing on our deck. A contractor told me to stay away from powder coated aluminum. He said the finish will fade in a year or so and shortly after that I will see some peeling of the finish. I learned he did powder coating several years ago and wonder if he is speaking from past experience and maybe not up on newer powder coating methods?
Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub.
I think the answer to that is solely dependent on how it is applied- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Powder Coat
Does this sound like a legit quality application or is it markety hype?
Fortress Fe26 steel railing is a pre-welded, easily customized and enhanced version of traditional wrought iron railing. It brings unparalleled quality to any patio, deck or balcony. The railing provides a clean, classic appearance that is versatile for a variety of applications and surfaces. Pre-galvanized steel, nano pretreatment, e-coat and premium powder coating make it the most elegant and durable steel railing system on the market.Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
I have Trex decking and the hand rail is the same stuff. Looks great after 27 years. I just pressure wash it once every 10 years or so.Gustard X26 Pro DAC
Trex is amazing stuff. I built a crawl space door out of it 15 years ago and it quite literally looks the same except maybe a little lighter- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The "plastic" decking has come a long ways in the last few years. We have TimbeTech on our front deck and looking to do the back deck with the same. This stuff does get hot in direct summer sun, but an outdoor carpet fixes that. Gonna have to do some work though as the back deck is 16" OC and I'm told go 12" OC to keep a firm feel to the deck under foot.Yep, my name really is Bob.
I have it on my front porch which is 16 oc and I have had substantial weight up there with zero issues or concerns.
My front porch is covered though- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Good to know. I think I'll just lay a few boards down and test them before doing any joist mods.Yep, my name really is Bob.
Mine is 16" OC but not sure if the new stuff is as rigid.Gustard X26 Pro DAC
Similar experience here. I asked a professional remodeler friend before building new front entry steps. He said 16 OC is okay, but some brands recommend 12. 16 was fine.
