Monitor 5B crossovers
DeRod
DeRod Posts: 249
edited March 2025 in Vintage Speakers
Going to try an inexpensive recap. Wanted to check the values of the old caps as well.
"Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
  • DeRod
    DeRod Posts: 249
    edited March 2025
    That’s the old 34uf electrolytic cap ☝️
    The old 12uf ☝️
  • Gardenstater
    Gardenstater Posts: 4,789
    edited March 2025
    The DF of 70.3% @ 10kHz (8% @ 1kHz), for that tweeter cap is insanely high (not to mention the ESR)! Polk specified DF less than or equal to 3% @ 1kHz for the caps in the Series II crossovers, on their schematic.
    Dissipation Factor refers to the tendency of the dielectric to absorb energy, which would be very undesireable for high frequency sound reproduction especially.
    If you're not testin', you're guessin'. 😉
    Post edited by Gardenstater on
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • DeRod
    DeRod Posts: 249
    edited March 2025
    The old resistor measures 2.8ohm .. the new new mills resistors measured 2.7ohm.
    The 3 Jantzen caps together measured 34.34uf
    The Clarity cap measured 11.82uf
    I’ll work on the second one tonight and check all the caps on that one as well.
