Shigaclone PS rebuild
bikerboy
I wanted to use my diy cd player a few months ago and it would not power up sometimes. I found a bad solder connection and all was well. As I worked on it I saw I didn't have a second capacitor in the regulator circuit. Now it has two black gate caps. That led to making a larger box for the power supply. I used leftover exotic wood since it is a small case. I think it turned at well and it sounds better also. Now I am comparing it to my PC files and I can't say either sounds better. Both sound great. The jvc boom box lives.
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Bottlehead Eros
CD: DIY Shigaclone
Very cool
President of Club Polk -
I'm digging that !!
Hell yeah 👍2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Just finished listening to Melody Gardot-Currency of Man. Beautiful voice and recording.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
Nice work! Great album too!
I've been using The Essential Melody Gardot double album on vinyl to test record.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
We have a bunch of her CDs but not vinyl. RTR recordings? I've been slowly digitizing my vinyl. Trying to downsize. Hard workMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Yes, RTR
recordings, to test them after repair/calibration. Digitizing vinyl is quite a project. I've done some but have many waiting.
I bought back my Yamaha gear from Aaron to reassemble a basement system. I had the Mitsubishi LT-5V vertical TT and a pair of Mission bookshelf speakers to complete it. One of these days I'll connect my music server to it. FM is via an attic antenna.
Now that the cd player is working great I had a cover made for it. Tap plastics did a great job. It was made with 1/4" acrylic. I going to get a similar one for the turntable next.
Bottlehead Eros
CD: DIY Shigaclone
That looks great! And thanks for sharing about Tap Plastics - that looks like a handy resource.I disabled signatures.
Got the TT cover from tap plastics. They did a great job. Finally got the TT free of dust. Now I can sleep well again. I also got a light that makes seeing dust and needle drops easier.
Bottlehead Eros
CD: DIY Shigaclone
Nice cover, fellow linear arm user! I used a local glass supply to build a custom sized plexi cover for my Lenco.
What are you using for cartridge wire? KAB Superflex is the best I have used. Extremely flexible, does not add any anti-skate.
I used a grill light for my TT.
I'm using cardas wire. It's very flexible. I'm thinking about moving the step up transformers inside the Eros just to make the interconnects shorter. Shouldn't be too much trouble. We'll see.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
