Powder coat or not?
Looking at installing railing on our deck. A contractor told me to stay away from powder coated aluminum. He said the finish will fade in a year or so and shortly after that I will see some peeling of the finish. I learned he did powder coating several years ago and wonder if he is speaking from past experience and maybe not up on newer powder coating methods?
Yep, my name really is Bob.
    VR3 Posts: 29,549
    I think the answer to that is solely dependent on how it is applied
    Viking64 Posts: 7,629
  • bcwsrt
    bcwsrt Posts: 2,509
    If you’ve ever had, or know someone who has, powder coated aluminum patio furniture, it does fade. Maybe not the first year, but eventually.
    Brian
    Toolfan66 Posts: 18,180
    Everything sun fades in time, some colors faster than others, my hand rails lasted about 15 years. Last year I took them down, had them bead blasted, and re-powder coated,
    The key is prep work, and use Super Durable Powder Coat.
    Even the aluminum, have them soft blasted before powder.
    It should give you many years of enjoyment..
  • muncybob
    muncybob Posts: 3,267
    Does this sound like a legit quality application or is it markety hype?
    Fortress Fe26 steel railing is a pre-welded, easily customized and enhanced version of traditional wrought iron railing. It brings unparalleled quality to any patio, deck or balcony. The railing provides a clean, classic appearance that is versatile for a variety of applications and surfaces. Pre-galvanized steel, nano pretreatment, e-coat and premium powder coating make it the most elegant and durable steel railing system on the market.
    audioluvr Posts: 5,987
    I have Trex decking and the hand rail is the same stuff. Looks great after 27 years. I just pressure wash it once every 10 years or so.
    VR3 Posts: 29,549
    Trex is amazing stuff. I built a crawl space door out of it 15 years ago and it quite literally looks the same except maybe a little lighter
  • muncybob
    The "plastic" decking has come a long ways in the last few years. We have TimbeTech on our front deck and looking to do the back deck with the same. This stuff does get hot in direct summer sun, but an outdoor carpet fixes that. Gonna have to do some work though as the back deck is 16" OC and I'm told go 12" OC to keep a firm feel to the deck under foot.
    VR3 Posts: 29,549
    I have it on my front porch which is 16 oc and I have had substantial weight up there with zero issues or concerns.
    My front porch is covered though
  • muncybob
    Good to know. I think I'll just lay a few boards down and test them before doing any joist mods.
    Mine is 16" OC but not sure if the new stuff is as rigid.
  • maxward
    maxward Posts: 1,718
    Similar experience here. I asked a professional remodeler friend before building new front entry steps. He said 16 OC is okay, but some brands recommend 12. 16 was fine.
