Early Model 7 Midwoofers
Gardenstater
Could 1975 Model 7 have possibly used this 6W10R CTS midwoofer, as this eBay seller is saying? Date code is 7503; 3rd week of 1975. Serial # pretty high at 44922.
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
iFi nano iDSD DAC
iPurifier3
Post edited by Gardenstater on
I ran across that sale when I was searching for woofers for my minis. I do believe that was probably used by Polk in some of the early 7s. If the guy had 2 I would have bought them just to check them out.
Thats from another seller. Apparently he has a pair of 7s he's parting out. One came with a peerless and the other with above pictured audax.
I think it would be cool to see a 7 with those CTS woofers and the Audax tweeters."Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb. -
I see what you’re saying about the serial number but are we sure how Polk kept track of the serial numbers from back then ?
That’s mine from early 1980. So a lower number than one from the 70s? Strange."Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb. -
They definitely started over with the 7A and the 7B, probably with the 7C and Series II as well.George / NJ
iFi nano iDSD DAC
iPurifier3
Who was JM ? He signed most all my early drivers and crossover JM or JMH"Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
Qts of 0.29 compares to MW6500 0.2190. Vas is 35L vs 75L (2.6486 ft^3) for MW6500, so it was a stiffer suspension.
George / NJ
iFi nano iDSD DAC
iPurifier3
Apparently Polk wasn't the only one at the time pairing the Audax tweeter with a square magnet midwoofer, although it does look different compared to the one above.
George / NJ
iFi nano iDSD DAC
iPurifier3
Looks like those had 3 big felt pads around the tweeters and whole front covered in felt around the mid woofer"Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
They look sort of like the monitor 4s without the port"Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
I was looking for stuff online the other night and ran across an old Polk woofer but was uncertain because it didn’t have a label on the back. Gardenstater confirmed for me that the woofer was indeed an MW6500
I thought it was cool that it predates the Polk labels on the back.
Thanks Gardenstater for your help on this one!"Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb. -
Here's an anomalous midwoofer to add to the thread. Black basket when all the ones of the period are silver basket, black back plate/T yoke with flats, voice coil wires go almost all the way out to the perimeter of the cone/surround. I wonder who made this one for Polk.
George / NJ
iFi nano iDSD DAC
iPurifier3
What's funny with those old 1970's Monitors is that when purchasing the speakers back then to get consecutive serial numbers was near impossible. This would make the chances that your speakers had mismatched woofers pretty high.
Post edited by DeRod on"Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb. -
I said near impossible 😂
That’s a rarity to see conservative numbers."Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb. -
I've got a pair of consecutive crossovers too 🤣
But regardless, if Polk was putting "MW6500" stickers on midwoofers sourced from different vendors, and treating them as interchangeable, theoretically there could be different sourced ones in consecutive serials. If they only have so many oddball ones they have to start and end somewhere.George / NJ
iFi nano iDSD DAC
iPurifier3
Well both you guys are special 😂
Just saying look at the guy that had 2 different tweeters in his."Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb. -
Yes to both 🤣
It would be interesting to look inside those speakers and see if the crossovers were different. I believe the Audax sensitivity being lower than the Peerless made Polk do the crossover differently regarding the resistors. I have seen only 1 resistor vs. 2, and the resistor is a much lower value in the Audax XO.George / NJ
iFi nano iDSD DAC
iPurifier3
I think he was selling the crossovers as well. They were the original ones that preceded the round circuit boards.
I can’t imagine that your left speaker having one tweeter and your right speaker having a different one would be a good thing."Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb. -
I couldn't see any dates on the tweeters or XOs but both XOs are the same. Single 2.7 ohm series resistor for the tweeter (not 4.5 or 4.7). I'm betting one of the original Audax got toasted and was replaced with a Peerless.George / NJ
iFi nano iDSD DAC
iPurifier3
God God those are artifacts
Gardenstater wrote: »I couldn't see any dates on the tweeters or XOs but both XOs are the same. Single 2.7 ohm series resistor for the tweeter (not 4.5 or 4.7). I'm betting one of the original Audax got toasted and was replaced with a Peerless.
Thats a fair assumption and the one that would probably make the most sense.
Still would have drove me crazy having 2 different tweeters
Bunch of nerdsPolitical Correctness'.........defined
President of Club Polk -
Bunch of nerds
Yes 😂😂
I always hated the term “audiophile”. I much more prefer “audionerd”"Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb. -
Close but no cigar! Can't expect much for $20.
Gardenstater wrote: »Here's an anomalous midwoofer to add to the thread. Black basket when all the ones of the period are silver basket, black back plate/T yoke with flats, voice coil wires go almost all the way out to the perimeter of the cone/surround. I wonder who made this one for Polk.
I had one of those come across the bench for re-centering. The magnet is much larger in diameter than the normal MWs, so I had to make a new tool to do it. Anyway so whoever made it, still didn't use good enough glue
my 3.1TLs
I will fix your shifted magnets for free.
