RaeIstic STA-90 DC Offset
drdave3
drdave3 Posts: 3
edited February 2025 in Electronics
I just got a Realistic STA-90. I had one when I was younger, sold it and regretted it. Now that I have another one, I discovered that when I put it on A&B speakers, one of the woofers burned up. I checked the DC offset voltage. On A speakers, it is normal. When I go to A plus B or B or quad it can jump up to 19 volts! In other words, the offset is fine on A speakers, but when I switch from there it jumps way up. Any solutions?
Answers
    msg Posts: 10,460
    Nice. I have an STA-84 that I like a lot, though, unfortunately, nothing to offer on diagnosis or repair.
    These guys might, though.
    In alphabetical order...
    @ALL212
    @mhardy6647
    @SCompRacer
    @SeleniumFalcon
    Gents? (applies to all but Ern; he's a scallywag)
    mhardy6647 Posts: 35,208
    That's puzzling.
    A+B should do no more, and no less, than parallel the power amp's outputs. I cannot grok offhand how that could unbalance the power amplifier. Of course, if that receiver has a quad synthesizer ("Quatravox", in R/S-speak) setting, I guess something could be awry there. Those "ambience extractors", though, are passive -- they use a simple wiring trick to send out of phase signals to the rear speakers.
    You might want to ask over @ audiokarma, @drdave3 -- of course, some of them will just say "recap it!". :#;) Hint -- that ain't likely to help!
    source: https://www.radioshackcatalogs.com/flipbook/1977_radioshack_catalog.html
  • Main amplifier alignment instructions and schematics are in the Service Manual ("service info") you can download here:
    https://www.hifiengine.com/manual_library/realistic/sta-90.shtml
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • The schematic for the output stage looks pretty normal, the output transistor pairs are fed plus and minus 39 volts, so that wouldn't account for the plus 19 volts at the output. @mhardy6647 is correct the speaker selectors seems to just connect the left and right outputs to two sets of speakers either separately or in parallel. Interestingly the headphone connection is fed directly from the output stage. What would needed to be done would be to trace backwards, finding the 19 volts and seeing where in the circuit it's being introduced. Either a transistor has shorted out, or a capacitor is leaking DC would be my guess.
  • Thank you very much. It just seems so odd that that voltage only appears when the B speakers are switched on.
  • I'm thinking must be something wrong with conductivity of A position, ie. maybe switch needs cleaning.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • drdave3
    drdave3 Posts: 3
    Replaced bias transistors and completely recapped the board. Plays fine on "A" speakers, but switched to "B" and bias voltage jumps to 13+ volts. I am beyond frustrated.
