M5jr vs M4.6 vs M4 for Dolby height
I'm looking to finish rounding out my HT setup, last positions I need are front height speakers and I'm trying to match the main L/R voicing.
All three options are within 1.5 hours drive, I'm leaning toward the M4.6 since it's the smallest that uses the normal tweeters but they are bare cabinet. I would have to drop in RD0-198s, mids and rebuild the crossover etc....
Hesitation is stemming from not wanting the speaker to be too large but it's probably a better idea to buy the 5jrs as they are working. These are the version with no PR to be clear
The 4s are much cheaper and are technically the smallest/closest by to me, but I know the tweeter is not interchangeable. However I'm not sure it would matter much in it's given job, thoughts?
2 channel: MXN10, Anthem MRX740, Anthem MCA5, SDA1c recap/RDO, JL Fathom F112V2, Tributaries series 8A, Tara labs RSC
Theater: Above plus Paradigm reference studio 100, Polk FX300i
Projects: SRS1.2TL, SRS 2, M5Jr+
Party/1st floor: iPad, Marantz SR5005, Paradigm reference S100v2, monster bulk cable
B&O H9 Gen3
  • DeRod
    DeRod Posts: 249
    I got a couple of M4 cabinets with the crossovers if you want them. You'll need the woofer and tweeters (MW6500 & Peerless)
    "Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
  • DeRod
    DeRod Posts: 249
    They are little shorter/less tall than the 5jr w/o the PR
  • StantonZ
    StantonZ Posts: 454
    I used a couple of Monitor 4's as Dolby Atmos ceiling speakers...until I installed a proper (Polk) ceiling speaker (see sig).
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • Striker2237
    Striker2237 Posts: 120
    edited January 2025
    StantonZ wrote: »
    How did they do?
    Drod, I may take you up on that offer. Thanks!
    B&O H9 Gen3
  • DeRod
    DeRod Posts: 249
    Let me know they are yours if you want them
    BTW - I got the grills for them as well
  • StantonZ
    StantonZ Posts: 454
    edited January 2025
    StantonZ wrote: »
    How did they do?
    They were great! The fact is, "height" speakers in Atmos don't see that much action (or dynamic range), so I replaced them with a true "in ceiling" speaker and moved my 4's to the bedroom...where their high quality can be better appreciated.
  • Striker2237
    StantonZ wrote: »
    StantonZ wrote: »
    How did they do?
    Oh awesome, for a second I was concerned that they didn't do well and got "fired" haha!
    I play a good amount of games and the height effects when stuff is flying overhead is enough to make me want to put better speakers up there, current ones are very noticeably mismatched with the rest in quality.
    B&O H9 Gen3
  • Striker2237
    DeRod, if I took you up on the M4 peerless cabinets would I be forced into using the peerless tweeters?
    I would prefer to use a pair of RD0-194s and MW6503s with needed crossover changes but I wouldn't want to have to hack up a nice pair of cabinets to do it....
    B&O H9 Gen3
  • DeRod
    DeRod Posts: 249
    Yes, I believe so. The peerless is a good tweeter though. The ones that are not so good are SL1000 & SL2000. For sure you would need to slightly modify the cabinet to use the 194.
    If you find an M5jr with the SL1000 and MW6502s those could be swapped for the 194 without any crossover changes.
    pitdogg2 Posts: 27,644
    DeRod wrote: »
    If you find an M5jr with the SL1000 and MW6502s those could be swapped for the 194 without any changes.
    You would still need to modify the tweeter cut out to work. The Peerless and SL1000 share the same cut out that will press the connecting tab for the wires into the magnet.
  • DeRod
    DeRod Posts: 249
    edited January 2025
    Yes, as pitdogg2 said, on the 5jr you would still need to slightly cut out the tweeter hole but you shouldn’t need change anything on the crossover.
