Questions about recently acquired Polk Audio SDA SRS 2 speakers
POLK3429
POLK3429 Posts: 26
edited January 2025 in Vintage Speakers
Recently acquired a set of Polk Audio SDA SRS 2 speakers and had a couple questions. Here is some info on the speakers
* They have the pin/pin connection, did not come with an interconnect cable, so I just bought one on ebay
* One serial number is in the 800's and the top/bottom caps are pieces of solid wood glued together. The laminated caps still look new - no cracks, warping, etc.
* The other serial number is in the 1600's and the caps are veneered
Was this model was sold from about 1986 to 1988? A "late 80's" confirmation is good enough for me.
Is there any significance/meaning to the serial numbers? No idea how many pairs they manufactured per year at the time, and therefore no idea how long it takes to go from 800's to 1600's ........ or if I should even care.
Anyone else have a pair of these SDA SRS 2's where the wood caps mismatch (one laminated & one veneered)? I did have a quick glance of at least one person replacing the caps - love the concept, but do not have the time.
    audioluvr Posts: 5,970
    I'm assuming you mean pin-blade interconnect? Pics would help.
    pitdogg2 Posts: 27,151
    Yes pictures because there are two completely different SDA SRS 2 speakers. One built of the SDA 1b and one off the SDA 1c not to mention they used very different drivers.
  • The interconnect is blade/blade - sorry for that brain lapse.
    The attached picture is what I have:
    - 2 x SL2000 H.E.
    - 4 x MW6509 Mid L.E.
    - 1x SW150 passive radiator
    Tony M Posts: 11,667
    I own a pair of them.
    I replaced the tweeters with replacement RD-0194's.
    You're in for a treat!!
  • Gardenstater
    Gardenstater Posts: 4,785
    The SDA Handbook is always the go to:
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Thanks for that info @Gardenstater! I did not know that a handbook existed, but after reading your post, I found this nugget (see picture). Is this the handbook that you reference?
    Yes that is the bible
    The B/b SRS 2 is more expensive to update the caps and the mw6509 drivers are as rare as hens teeth. The mw6509 was only used in the SDA 1b and the model you have. Probably the shortest run driver of them all.
  • pitdogg2 wrote: »
    Thanks for the info. That is not ideal news about the MW6509 being rare, but I bought them without doing much research.
  • I am enjoying these so far just as-is. The bass response is impressive for a 40 year old speaker.
  • TroyD
    TroyD Posts: 13,124
    While I think the 2.3tl is the true SDA sweet spot…….I think the SRS 2’s are special as well.
    BDT
    All I've heard had a huge sound stage.
  • Schurkey
    Schurkey Posts: 2,122
    I'd expect the SRS 2.3 "Donut drivers" to be even more rare.
    F1nut Posts: 51,872
    Schurkey wrote: »
    You need some?
  • Schurkey
    edited February 2025
    Schurkey wrote: »
    You need some?
    Me? No, thanks. Those were 6513...right?
    Probably should have looked into the 6510/6511s that were on eBay recently, though. I have spares of one or the other, I don't remember which.
    F1nut Posts: 51,872
    Yes and very rare, but I have some.
  • pitdogg2 wrote: »
    These SDA SRS 2's do seem to have a large sound stage. The seller claimed they were unmodified, and I have not disassembled yet to verify. I am sure everyone has songs they use, but Neil Diamond's 'Soolaimon' has percussion events that happen outside both the left & right speakers on these SDA SRS 2's.
    I just picked up a 2nd pair of SDA's, a pair of SDA 1c's that have been modified, but the Neil Diamond 'Soolaimon' song does not have the SDA effect. I can pinpoint the sound as coming from the speakers (almost no sound stage) - which is very disappointing. I will probably need to disassemble the 1c's to trouble shoot, and start a separate thread.
  • I bought my SDA SRS 2's blade/blade September 1987. Andreas Vollenweider "Caverna Magica" sounds good. Speakers are original, no mods, nothing.
  • Schurkey
    When you finally get around to replacing the capacitors, the SDA inductor, and the tweeters, you're gonna be AMAZED. While you're in there, lift the fiber packing back up where it belongs, instead of drooping down into the bassive radiator area. Fresh resistors, other exotic mods optional.
    I was, when I did that to my SDA 1Bs--same guts except for one resistor, smaller cabinet, smaller bassive radiator.
    F1nut Posts: 51,872
    Passive radiator
  • Schurkey wrote: »
    You got me interested now. Where do I buy these parts? All the other mods have diminishing returns? I just read the bible, very informative.
  • Schurkey
    There's a hundred vendors for capacitors and resistors. Folks on this forum have their favorites. ERSE--or what used to be ERSE but is now something else--seems to be a preferred source for inductors, although again, there are other sources.
    When it was me, I bought 1% tolerance Dayton capacitors from Parts Express for the high-frequencies, 5% Dayton for the low-frequency section, and four bigass 91uF 3% tolerance ERSE PulseX capacitors for the SDA. None of those caps are on the "approved" list on this web site, and yet I'm completely thrilled with them. ANY film cap is going to be better than the worn-out, ancient electrolytic caps in there now. Hell, even FRESH electrolytics would be better than the original electrolytics.
    IF (big IF) you have a decent amplifier, you can eliminate the polyswitch "tweeter protection". Some folks replace it with a low-value resistor, 1/4 or 1/2 ohm. I just bypassed it with a jumper wire, which increases treble volume slightly--much needed on my 1Bs, and I suspect on your SDA 2s as well.
  • Schurkey
    Passive radiator
    I prefer Bassive radiator, as that is also the frequency range it provides.
    F1nut Posts: 51,872
    Schurkey wrote: »
    Sonic Craft and Parts Connexion carry the better components. There's also HiFi Collective in the UK. They carry a lot of components that no one else does. My latest order from them is on the way B)
    Some reading for you. Dayton is not mentioned, but the Bennic XPP is the exact same thing.
    https://www.humblehomemadehifi.com/Cap.html
    Toolfan66 Posts: 18,119
    Schurkey wrote: »
    What are you working on? B)
    msg Posts: 10,452
    Toolfan66 wrote: »
    Something Van Halen-related.
