Which banana plug are suitable for polk speaker E15
Model E15
Answers
    F1nut Posts: 51,722
    Any brand will work.
  • Model E15
    bare wire. why add another connection into the circuit if you do not have to? binding posts are made to accept bare wire. sure a pain to connect, but once done typically not visible. pure snake oil, only advantage is if equipment will be swapped out on a regular basis ( store display racks etc) why waste money on them.
    F1nut Posts: 51,722
    ^Such flawed logic is laughable^
  • ChaseHifi
    ChaseHifi Posts: 4
    Please, tell us how adding another connection at each end of the wire will help. Have you ever even bothered to measure the resistance created when you add your beloved banana plugs? The difference is typically negligible, but is measurable with even a basic quality dvom like a fluke 87. It's not flawed logic, it's fact
    But hey what do I know about an ac circuit? Only been an active maintenance technician troubleshooting shorts, and so much more for over 20 years now
    It's fine to state you feel my logic is flawed, but when you back it up with nothing (probably to justify the snake oil interconnect you paid %20 of total system cost on) where is your fact based scientific research and data to prove it sir? It doesn't exist, plenty of data showing how connections, particularly poor connections, can and do cause electric signal degradation. Audio output is nothing more than a bunch of ac voltage at various hz. Anytime you put a break in the line and add a connection the signal is degraded. Period.
    F1nut Posts: 51,722
    edited January 5
    You're funny. Enjoy your lamp cord.
  • daddyjt
    daddyjt Posts: 3,057
    ChaseHifi wrote: »
    Your assertions are incorrect. There are several disadvantages to bare wire connections at speakers and amplifiers, including oxidation (banana terminations are typically gold/rhodium plated), strand breakage, shorting, etc. I too use a Fluke 87V for quick measurements, but I more often use an HP3478A, as it’s much more accurate for electronics work - and I can assure you that there is no added resistance or signal loss with bananas. If you are measuring added resistance, then either your measurement method is flawed, or you are using extremely poor quality banana plugs.
    Also, there is a significant difference between an electronics technician and a maintenance technician. Audio circuits are far more complex than electrical supply circuits, and your expertise in the later is no guarantee of proficiency in the former. If fact, your assertions would suggest that you have little experience with audio circuits. If you prefer bare wire connections, great. But saying bare wire is superior is simply incorrect. Period.
    ― Aleksandr Solzhenitsyn
  • gyosa
    gyosa Posts: 770
    I prefer to use a high quality spade connector soldered to the wire - Kimber Kable PostMaster is my favorite - always a nice , tight , secure connection.
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    msg Posts: 10,452
    edited January 9
    @gyosa - woh, those are of nteresting design. (at least this first example I came across is, to me, somewhat unique)
    https://kimber.com/connectors/postmaster-33
  • gyosa
    gyosa Posts: 770
    Amazingly secure connection.
    The “wafer” really does what it’s supposed to do.
    Bk
    msg Posts: 10,452
    Yes, I was reading about the wager bit. I like that.
    I've used spades that have upturned lugs at the end, and grip lines on them, which help to maintain the binding post nut grip. These work pretty well, but that compression wafer, acting like a spring or elastomer seems like the ticket.
    I'd like to try these. Affordable, too.
    Curious about that "Wonder Solder". Need to read up on this.
    Are the connectors pre-flowed with solder, so that you only need to heat them once assembled, or is it a small measure of solder off of a spool that they provide?
    I like the mechanical crimp in addition to solder.
  • gyosa
    gyosa Posts: 770
    edited January 9
    They provide the solder and shrink wrap…
    Easy peasy to do… insert wire , crimp , solder then heat the shrink wrap !
    Get the right size for your binding posts … they make 3 …. I use the 33’s , the largest - fit my Salks perfectly , a tad too small for my Ascends , but they fit fine if put on sideways .
    Bk
    msg Posts: 10,452
    I like it. Nice.
  • haudevbe
    haudevbe Posts: 17
    Polk Audio E15 speakers (possibly meaning Signature E15 or TSi100/E15) are passive bookshelf speakers with an 8-ohm impedance.
    Can Bi-Amping Make Them 4 Ohms?
    No, bi-amping does not change impedance. The crossover inside the speaker still divides the frequencies between the woofer and tweeter, keeping the load at 8 ohms per terminal pair.
