Foam replacements for R15 bookshelfs
MrGlock2
I haven’t had any luck in finding a source for replacement woofer foams on my R15 speakers. If anyone knows where I can find them I would appreciate the advice.
Thank you.
Thank you.
Answers
The surrounds are rubber not foam.
Good to know. I just hope I can find them! THANK YOU Sir !!
"Simply Speakers" has surrounds of certain sizes.
measure the 4 measurements A B C and D and see if they carry a matching rubber replacement set.
They probably do. OH...5.25" woofers...ok.
ebay;
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2332490.m570.l1313&_nkw=polk+audio+R15+woofers&_sacat=0
I bought rubber surrounds for a little-known brand from Simply Speakers a year or 2 ago. The charts are on their site. Measure them up.
https://www.simplyspeakers.com/
https://www.simplyspeakers.com/rubber-speaker-repair-edge-kits.html
rubber...generic size
https://www.simplyspeakers.com/speaker-rubber-edge-repair-kit-rsk-5.25.html
These are foam...Polk replacements for some models
https://www.simplyspeakers.com/polk-audio-speaker-foam-edge-repair-kit-fsk-5s.htmlMost people just listen to music and watch movies. I EXPERIENCE them.
Just save yourself the headache and buy a whole new driver.
Call Polk customer service and tell them your problem and tell them you are a member of the forum. -
I should have asked this from the start, why do you need new surrounds? Rubber surrounds last for multiple decades.
The R15 was never intended to be repaired only replaced if necessary, hence there are no replacement parts available from Polk. Sorry.
SeleniumFalcon wrote: »The R15 was never intended to be repaired only replaced if necessary, hence there are no replacement parts available from Polk. Sorry.
As in drivers Ken? -
Correct, no tweeters or drivers or crossovers.
Thank you!
