Polk Monitor 7 crossover upgrade question
maawr1230
maawr1230 Posts: 3
edited November 2024 in Vintage Speakers
I am trying to teach myself how to recap and see lots of different information online. I have been reading posts on this forum and understand that Sonicap is who to use. The stock crossover has a 3.4uf Electrolytic cap on it and I was wanting to know if I can change it out with a film cap or do I keep it Electrolytic? I apologize if this is a question already asked and answered on the forum. I am looking at using the Gen 1 Sonicap capacitors and Mills resistors. Also it looks like I can use a Mills .5ohm for the poly switch replacement? Thank you guys in advance.
Best Answer
    Toolfan66 Posts: 18,412
    Answer ✓
    I have used many different caps on many different Vintage Polk Speakers over the years, and IMO, Sonicaps and Vintage Polks = Magic..
    YMMV.
Answers
  • maawr1230
    here a picture of my crossover.
    pitdogg2 Posts: 27,881
    That is a 34uf NOT 3.4uf. you will need to use two 17uf to get the value. When you parallel two caps to make value you want to be as close to half value as possible. In other words do not use a 30uf and a 4uf to make value. To use a 30 and a 4 the smaller cap will act more like a bypass cap which is not what you want. Make your resistors higher wattage than stock, use 10 or 12 watt resistors, more better.
    Put your 12uf poly cap on first then the paralleled caps on second. That way you can use double sided foam tape on the 12uf to help support the two paralleled caps. Understand that the poly caps will be much bigger than the caps now, so you must get a little creative to fit all. With the one hole in the board near the inductor you can run a long zip tie through to the edge and zip tie all down.
    To answer your question Yes you want to change out that 34 electrolytic. It is way past its prime and could be way past its value as it was most likely +/- 10% anyway.
    Clear as mud 😉
  • maawr1230
    thank you so much for the answer, I sincerely appreciate it. I knew I came to the right place
    F1nut Posts: 52,381
