Polk SUB PSW-10
crr119
I recently purchased a used Polk subwoofer, the PSW-10. I have an older receiver, Pioneer VSX-5700S, which doesn't have a specific subwoofer port (RCA connection) on back like many newer receivers do. What is the best way to wire my new sub to this receiver? I am using four speakers...two Bose 301 and 2 Advent Heritage.
Thank you
Thank you
Best Answer
You will want to run an additional pair of speaker wires from the receiver to the corresponding speaker level inputs on the subwoofer.
Answers
I also got a Polk Audio psw-10 off of Facebook marketplace
I also bought a set of Polk speakers off Facebook Marketplace. There is a pair of Monitor 60 tower speakers, a PSW10 subwoofer, plus a center channel. We're trying to connect them to a Sony STR-D590 which has no Sub Out.
I found an owner's manual for the PSW10 which shows speaker level inputs, however the back of the PSW10 we have has RCA jacks for Line In, and the connectors that the manual calls Speaker Level Inputs are labeled Speaker Out on our subwoofer! Please advise! Thanks! -
Hello,
Welcome to the Polk forum. This is what the rear panel should look like:
Thank you so much! The picture I had didn't show the label on the bottom row! That makes a big difference!
You're welcome, I'm glad the information was helpful.
It was! They are all hooked up and sounding great!
