Picked up some 7b's for free!
A buddy of mine had a set of 7b's sitting in his basement, and he gave them to me for free recently (I *did* offer him payment, but he wouldn't take it), with a warning that one of the tweeters (which appear to be Peerless, correct?) was bad:
When I got them home and checked them out, as many of you probably guessed the tweeter problem turned out to be a bad fuse. Replaced it and the tweeter lit right up. Can't be happier with them - they sound amazing set up on a couple of makeshift stands, even if cosmetically they're a little rough around the edges.
About that, I notice that on the top of both speakers there are three dimples in the veneer that look like the top of a screw or a nail. On one them, there's bubbling under the veneer that seems most likely to me to be corrosion from such a fastener:
Is there bracing in this area that would use fasteners? Any idea what these dimples might be?
Eventually I plan to re-veneer and re-cap them, but my priority now is to pull the woofer and secure the magnet - it hasn't come loose yet, but an ounce of prevention, etc.
Here they are in situ - placement isn't ideal, and I need to get a legitimate set of speaker stands, but it all works for now:
    F1nut Posts: 51,802
    Someone likely had them mounted. There is nothing in the speakers to cause that. Have you looked at the bottoms for other screws?
    That's a vinyl covering, not wood veneer.
  • buckaroo
    buckaroo Posts: 6
    edited November 2024
    Yeah, I figured it was vinyl - just used the wrong word :) . I want to peel it off and replace it with real wood veneer eventually.
    I thought about the possibility of screw-mounting points (yes, the marks are on the bottom as well), but it didn't make sense to me that the vinyl is unbroken. I wonder if something heavy was sitting on it? But then what would the apparent corrosion bubbling under the vinyl be? Unless the vinyl is not original? I guess I won't find out until I peel it all off...
    F1nut Posts: 51,802
    It's original vinyl.
    The vinyl is broken, it has screws driven into it.
    The bubbling is the particleboard falling apart and trapped under the vinyl.
    You'll need a heat gun to help remove the vinyl. Best to start on a back edge corner. Heat a small area, pull up that small area, heat another small area and repeat until skinned clean. Fair warning, it isn't easy.
  • F1nut wrote: »
    At first I thought, "no way. I'm looking right at it, and it's unbroken." But then I looked closer, and started poking at it, and it turns out that you're of course correct: it looks to just be a really well color-matched waxy filler, probably something like this: https://www.fastcap.com/product/softwax-kit.
    That puts that "mystery" to bed.
    And yeah, getting the old vinyl off is going to be a bear - that's why I'm saving it for last, after I address other age-related maintenance. I'm just tickled to have such a great-sounding set of classic speakers, regardless of looks.
  • boston1450
    boston1450 Posts: 7,758
    Have you done a air leak test yet ? Are the holes thru ? Push in & HOLD IN on the passive & watch the MW come out. Should stay out 3-5 seconds before going back to resting position. If less then you got leak
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    mhardy6647 Posts: 35,050
    Numerous reports here and at - ahem - certain dumpster-diver web forums ;) of de-vinyling these old cabinets. It looks (to use a phrase from math textbooks) straightforward.
  • buckaroo
    buckaroo Posts: 6
    boston1450 wrote: »
    No leaks, happily!
    I'll dig around - it'll be good to see what I'm in for!
    Loving the sound of these more and more the longer I listen to them - if I had to characterize them, I'd say they're "relaxed" or "laid back." An entirely pleasant listen, no fatiguing harshness at all.
    txcoastal1 Posts: 13,513
    Toolfan66 wrote: »
    Yeah, yeah, but they are still very cool😎
  • Toolfan66 wrote: »
    Holy Moley :D ! Not my style, but ya gotta admire the attention to detail!
  • skrol
    skrol Posts: 3,452
    If you remove the mid-woofer or PR, make sure the batting is pushed up into place behind the mid-woofer and tweeter but not behind the PR. It tends to fall down.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol wrote: »
    Good advice, thanks!
