RTi A5 Woofer
I just upgraded my home AVR and started hearing a slight crackling from one of the woofers on my RTI A5 speakers. I can't find a replacement for the RD6547-1-E woofer. My question is, can I replace that woofer with another 6.5" woofer from the RTi series.
    F1nut Posts: 51,778
    Have you called Polk to see if they have any or if not, what might be a suitable replacement?
  • I checked with Polk and there RD65747-1 drivers available, call 1-800-377-7655 and follow the prompts to the parts ordering department.
  • Kogzz
    Kogzz Posts: 2
    Well, my impatience just got the best of me. Ordered a RTi8 6.5" woofer off eBay.
    F1nut Posts: 51,778
    Kogzz wrote: »
    That has a completely different part number, which tends to mean it has completely different specs.
