HereI go again. Receiver hook up issue
Equipment
TV 55" Sony
2x T15 Speakers
1 PSW10 Woofer
Sony STR DH550
Receiver is about 10 and probably borderline obsolete but these things never die. Speakers are awesome bookshelf and woofer. I dont neen bigger. Well each and every time I move my TV I have trouble hooking up correct ports. Just when I have speakers working on TV, Smart APP AM/FM my woofers are not working. I even back checked myself by a trip to Best Buy. It should not be this hard. OK I am ready to upgrade the receiver. Even called Polk for a receiver recommendation and had to go to Tech Support for that answer. Is there a better receiver non bluetooth that will perform and is easier to set up?
    F1nut Posts: 52,381
    The speaker and subwoofer connections are clearly marked on the rear panel of every AVR made. Maybe it's time for glasses?
  • Emlyn
    Emlyn Posts: 4,901
    Once it's set up and working the way you want it to take a photo of the rear of the receiver with all the cables connected for future reference. A ten year old receiver isn't obsolete for basic functions.
    But, you're unlikely to find a receiver more basic to set up than the DH550.
    https://www.crutchfield.com/S-0hMnpH7KvGa/p_158STDH550/Sony-STR-DH550.html?archived=/1000#&gid=1&pid=3
    mhardy6647 Posts: 35,555
    obsolete?!?
    heh-heh-heh...
    As long as there are RCA jacks and five-way binding posts... nothing will be obsolete ..
    B)
  • Geoff4rfc
    Geoff4rfc Posts: 3,047
    obsolete?!?
    heh-heh-heh...
    B)
    "Old....not obsolete"
