HereI go again. Receiver hook up issue
Equipment
TV 55" Sony
2x T15 Speakers
1 PSW10 Woofer
Sony STR DH550
Receiver is about 10 and probably borderline obsolete but these things never die. Speakers are awesome bookshelf and woofer. I dont neen bigger. Well each and every time I move my TV I have trouble hooking up correct ports. Just when I have speakers working on TV, Smart APP AM/FM my woofers are not working. I even back checked myself by a trip to Best Buy. It should not be this hard. OK I am ready to upgrade the receiver. Even called Polk for a receiver recommendation and had to go to Tech Support for that answer. Is there a better receiver non bluetooth that will perform and is easier to set up?
    F1nut Posts: 51,881
    The speaker and subwoofer connections are clearly marked on the rear panel of every AVR made. Maybe it's time for glasses?
  • Emlyn
    Emlyn Posts: 4,786
    Once it's set up and working the way you want it to take a photo of the rear of the receiver with all the cables connected for future reference. A ten year old receiver isn't obsolete for basic functions.
    But, you're unlikely to find a receiver more basic to set up than the DH550.
    https://www.crutchfield.com/S-0hMnpH7KvGa/p_158STDH550/Sony-STR-DH550.html?archived=/1000#&gid=1&pid=3
    mhardy6647 Posts: 35,145
    obsolete?!?
    heh-heh-heh...
    As long as there are RCA jacks and five-way binding posts... nothing will be obsolete ..
    B)
  • Geoff4rfc
    Geoff4rfc Posts: 2,892
    obsolete?!?
    heh-heh-heh...
    B)
    "Old....not obsolete"
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
