PSW10 Power
I have this sub powered through a separate power strip. Even though I leave the toggle switch on (middle), whenever I turn the power strip on I still have to switch on sub in order for the light to get green. A bit annoying, but that's not actually the issue.
I already set this sub up through my Pioneer's automatic MCACC process, so I know its working. Like I said, I prefer to keep the power switch in the on (middle) position. However, I've noticed that after using my surround system for a while the green light turns red. My guess is after about 15 minutes. I assume that means the power is off. Anybody know what this means?
  • Unknown
    F1nut Posts: 52,406
    edited May 2021
    The middle position of the power switch on the sub is the AUTO on option. If the sub does not receive a low frequency signal to wake it up it will not come on. Also, you do not have to turn the power strip off when the sub is not in use. In fact, don't use a crappy power strip at all. Plug the sub into the wall outlet.
    Your sub is not receiving a signal from your AVR. How do you have the sub connected to the AVR?
  • Kathysj
    Mini plug broke off in jack receptacle. How can I get it out
    F1nut Posts: 52,406
    Got a photo?
