Bluesound Node 2i power board conversion (Karma)
newbie308
I upgraded the power board in my Node 2, but the board I originally ordered was for the 2i (and maybe others) My Node had a different power header, so I ended up purchasing a second filter board to work with it. The board that I am offering has a four pin header and a two pin header. Approximately an $80 value. If you are curious what the power board conversion will do for your Node 2i, now is your chance. You will need to provide your own 5v DC power supply. This is open to all established club Polk members with at least 100 posts. Pick a number between 1 and 50. I will use a random number generator to select the winner when I return from my business trip on Monday August 26th.
Here is a photo for reference.
Enjoying the journey while never attaining the destination. -
Hmm...I wonder if this works with the newest node with hdmi? Guess I'll have to investigate!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I guess this karma was too obscure. @rooftop59 If you want to try this power supply board, let me know and I will mail it to you since you were the only member to show any interest in it.Enjoying the journey while never attaining the destination.
I'm generous of you, bud, but I did some quick research, and it appears that the N130 with HDMI uses a different board. But thanks for the offer!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
