How to remove tweeter from Polk r600
elmm75
elmm75 Posts: 6
Best Answers
Answers
  • elmm75
    elmm75 Posts: 6
    I am a new member here and I love my Polk speakers. I had picked up 1R600 from eBay for 150 and it had a tiny dent on back right corner. Heck of a deal. So I picked up another one that was open box from safe and sound. Within 5 minutes of playing I tuned the volume up and instantly both of my tweeters fried in both of my R600. Idk what happened. I had been playing the one r600 from eBay for a couple weeks and running a lsim703 on the right till I got my safe and sound r600. I just don’t understand what could have caused this
    Viking64 Posts: 7,608
    I'll just have a seat right here and wait for elmm75 to show us "how to remove tweeter from Polk r600".
  • Gardenstater
    Gardenstater Posts: 4,801
    Well first question is how loud did you turn it up, like past 12 oclock? What is your power source?
    Usually the common belief is that something must be wrong with your amplifier for this to happen.
    There are certainly members here who have removed tweeters in the L series and R series recently and can advise.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • elmm75
    elmm75 Posts: 6
    I have an anthem mrx720 and use it as preamplifier into smsl su9 pro to an emotiva a300. Turned it up about 67% of max volume.
    msg Posts: 10,458
    What is max volume? What is the scale?
  • elmm75
    elmm75 Posts: 6
    Geeez if you don’t understand what the scale is of 67% u need more help than I do. Lmao
    treitz3 Posts: 20,076
    LOL...
    @elmm75....while I cannot answer your query? Others can.
    Sometimes, it takes a while for someone to chime in that has experience with this. With that said...
    Please allow me to offer you a very warm welcome to Club Polk.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,295
    @VR3 is right on the mark, as usual. My friend sent along this drawing:
  • Emlyn
    Emlyn Posts: 4,807
    I understand the vanity ring for the tweeter is also magnetic (likely lightly glued/taped as well) while the one of the midwoofer is held in by pins and easily removed. I have removed the ring for the midwoofer but haven't tried the ring for the tweeter. I have heard that the ring for the tweeter is somewhat difficult to remove without marring the cabinet.
    Once either is removed it's just a normal set of screws holding the drivers in the cabinet.
    Clipdat Posts: 13,100
    Why even bother swapping out the tweeters though if you're just going to blow them again?
    You're welcome.
    What kind of source and amplification are you running?
    pitdogg2 Posts: 27,220
    edited July 2024
    elmm75 wrote: »
    Tom ^^^
    I'm not sure what this smsl su9 pro is honestly
  • Emlyn
    Emlyn Posts: 4,807
    The SMSL SU9 is a decent quality budget DAC. The Emotiva A300 is a decent quality budget amplifier around 150 watts per channel.
    Neither by themselves should contribute to damaging tweeters in R600s in normal usage.
    @Emlyn running the A300 at 67% could cause problems one would think. Depending on the music you're probably real close to running out of gas.
    F1nut Posts: 51,938
    running the A300 at 67% will absolutely cause blown tweeters
    Fixed it.
    edited July 2024
    "I have an anthem mrx720 and use it as preamplifier into smsl su9 pro to an emotiva a300."
    According to his original post he's running an AVR as a preamp (how? its digital out??) into a SMSL DAC, and then into an entry-level Emotiva amplifier with the following specs.
    Type: Solid-state stereo amplifier
    Power Output (two channels driven)
    150 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.1%; into 8 Ohms
    300 watts RMS per channel; 1 kHz; THD < 1%; into 4 Ohms
    Power Band width: 20 Hz to 20 kHz (+ / - 0.07 dB).
    Broad Band Frequency Response: 5 Hz to 80 kHz (+ / - 1.8 dB).
    THD + noise: < 0.02% (A-weighted); at rated power; 1 kHz; 8 Ohms
    Signal to Noise Ratio (8 Ohm load)
    > 120 dB (A-weighted); ref rated power.
    > 100 dB (A-weighted); ref 1 watt.
    Minimum Recommended Load Impedance:
    4 Ohms; which equals one 4 Ohm load or two paralleled 8 Ohm loads.
    Damping Factor (8 Ohm load): > 500.
    Power Supply: Linear power supply with heavy duty toroidal transformer.
    Input Sensitivity (for rated power; 8Ohm load): 1.2 V.
    Gain: 29 dB.
    Dimensions: 17" x 4" x 15.5" (WxHxD not including connectors)
    Weight: 25.2 lbs.
    Price: $399
    But yeah not clear on the AVR into a DAC thing. Don't do that!
    VR3 Posts: 29,526
    that receiver does have pre outs it seems
    Optical out of the Anthem into the DAC?! Makes no sense and might clip your digital output level and mess up everything downstream.
    VR3 Posts: 29,526
    Yeah not sure about running a 5.1 receiver with a 2 channel dac, can't say I hehe done that one before
    Either run the SMSL DAC straight into the amp using the variable volume control, or run the DAC's fixed line level output into one of the AVR's analog inputs.
    msg Posts: 10,458
  • Emlyn
    Emlyn Posts: 4,807
    edited July 2024
    I'm not sure there's much to be gained by using the Emotiva amp if the system is just stereo. That Anthem receiver has a decent amp section in it and the R600s aren't difficult speakers to drive.
    My guess is the "67 percent" is referring to the receiver's volume display set to show absolute volume (min or zero to max) rather than relative (minus something to 0 as the THX 75dB dialog level). A 67 volume level on an AV receiver set to show absolute volume isn't usually very loud. In analog audio a volume knob set at 67 percent of max (2 or 3 o'clock for example) would be very loud and enough to damage speakers. It's also true that Emotiva amps used to have relatively high output gain so if the AV receiver based system isn't properly set up to a 75dB reference level it's possible what the volume display is showing isn't showing what the amplifier downstream is outputting to the speakers.
    msg Posts: 10,458
    A guess, yes, and same with my first response without looking up the manual to determine context.
    I did ref the Anthem manual yesterday eve - the range and scale doesn't appear to be specified, btw.
    Yeap, and for the sake of additional examples, I've seen volume controls on AVRs and pre/processors with 0-100 - what seems like some general arbitrary range - and another with -90 to +112 for a dB scale, 0 being reference on that particular unit.
    Not knowing at the time what kind of gear is or volume control this Anthem uses, it wasn't possible to determine whether volume was e damaging factor, though either way pretty obvious it was, regardless of the setup. The question is, what can be reviewed and adjusted/learned with the setup.
    My initial thought was that if it were a 2ch piece with an analog volume control, "67%" of total travel - if that figure were an off the cuff estimate - would be way into red range for most units, not to mention uncomfortably loud if not eased up to it over a long listening session. Hearing damage levels for most, regardless, if sustained. Easy to see how tweeters could have been damaged in this case, the obvious solution the next go round being to turn it down.
    The effort was early info gathering in the attempt to assist, the presumption being that 67 was either a displayed 67 with the owner either knowing or assuming 100 max level, or an estimate of volume level. Either was meaningless without more info or context of the control type and scale, or even the range. 98.7% of people throw percentage stats around probably 43% of the time. This is a fact. One I just made up, but a fact nonetheless.
    The description of connections doesn't make sense.
    Connections are more clearly described by signal flow from source to destination. I agree, the DAC should be in front of the Anthem, yes.
    Otherwise, as noted above, there would likely be an additional variable level control in place, unless one of the devices is set to fixed output level, possible in some cases. Anyway, this part doesn't make sense at all, since it would be like a preamp into a preamp for some reason. No mention of the source devices in use that I could see on last update skim.
    I was also wondering whether any of the pieces in the mix have gain controls. This is a factor even when properly connected.
    OP might check Anthem inputs, the amp, and the DAC for respective gain controls and see that they're defaulted. If the devices are not new, would suggest factory reset of all components as best practice.
    The reason that device inputs have gain adjustments is in order to match all source relative volume levels (for those who may not be aware). Some people use the gain control knobs on the rear of some amplifiers. Parasound for example. I do not, and I have these set max. All other control is at the processor.
    Acquire and read the manuals, even if it doesn't all make sense right now. It will later.
  • Gardenstater
    @elmm75 I don't know how old or "vintage" your equipment is but this is pretty interesting regarding glitches that can occur that may or may not trip the protection circuit. If the amp doesn't go into protection mode, something's gonna get fried.
    https://www.youtube.com/watch?v=UFH5IP4wl9I
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
