Dayens Menuetto Owners
Hermitism
Hermitism Posts: 4,332
Has anyone had any issues with the on/off rocker switch locking up in the off position and not being able to be pushed into the on position?
    F1nut Posts: 51,937
    Looks like it is a press fit rocker with some glue added. There are all kinds of replacements available, this is but one.
    https://www.sparkfun.com/products/11155
  • Hermitism
    Yeah, this thing's as cheap as the remote it comes with.
    pitdogg2 Posts: 27,218
    Couldn't you put a better switch in it? I mean what's $10...😜😬
  • Hermitism
    Do they make a switch that will turn this into the quality of a Marantz?
    F1nut Posts: 51,937
    edited June 2024
    No!
    There are push button switches, which are usually better, but you don't have much depth room and they tend to be deeper than a rocker, so you would need to do some measuring and careful shopping.
    msg Posts: 10,458
    edited June 2024
    Any bypass options in the meantime?
    Post edited by msg on
  • CottageChz
    CottageChz Posts: 417
    I haven’t had that issue. Mine doesn’t get a ton of use, though.
  • Hermitism
    edited June 2024
    Here are some photos on the innards.
    Internet pic of the way the back of the switch looks. Four wires connect to it.
    SCI R13-112
  • Hermitism
    For anyone that has to replace their switch in the future...
    You have two thicker gauge wires for the power and two thinner gauge wires for the light and a four post switch.
    Post 1: thick solid brown wire
    Post 2: thick solid yellow wire
    Post 3 Positive: thin solid white wire
    Post 3 Negative: thin solid brown wire
    The two thicker wires can be pulled through the hole and soldered outside the unit. The two thinner wires have no extra length and the other ends are soldered to the board in the rear of the unit, labeled "motor". The two thinner wires have to be soldered after the switch has been installed in the hole. Not a lot of room to do so. And a four post switch seems to be rare.
    F1nut Posts: 51,937
    You might be able to retro-fit this one. It may also help you search for a round one.
    https://www.hificollective.co.uk/switches/edk-sc-wl-spst-rocker-switch-red-illuminator.html
  • stangman67
    stangman67 Posts: 2,328
    Would think you can grab the part number off the switch and replicate?
    msg Posts: 10,458
    @Hermitism - nice work so far getting that apart.
    F1nut Posts: 51,937
  • Hermitism
    I can't believe you found that! Thank you!
  • CottageChz
    That’s some great sleuthin’
    F1nut Posts: 51,937
    Hermitism wrote: »
    You're welcome. Probably a good idea to buy more than one.
    msg Posts: 10,458
    Is this thing fixed yet?
  • Hermitism
    Parts arrive Saturday. Ordered two. I contacted Dayens over the weekend before posting here. Zoran reached out on Monday and provided a link to a US source for the switch. We now have a couple sources if anyone here needs their switch replaced in the future, thanks to Jesse and Zoran. Apparently, I was not competent enough to find one on my own. And I tried.
    The Dynamat treatment is complete. The lid is a heavier gauge metal than any of my other components. On the others, once you slide the lid back enough to clear the front face plate, you can pull out on the sides and lift straight up. You can't do that with the Menuetto. You have to slide it straight back to remove the top and it's a tight fit. So, Dynamating the inside of the lid is not an option.
    There are two plastic bearings in the face plate that the rods slide through for the knobs. The fit could have been tighter. I understand the money for the construction went towards sound quality, and the knobs turn nicely, but you can wiggle them slightly. My OCD will force me to have a compulsion to wiggle the knobs every time I pass by. Then touch the power button three times and bark once.
    We need a video of that brah!
    msg Posts: 10,458
    No we don't.
    msg Posts: 10,458
    My OCD wants to force you to clamp those leads together and power that thing on. Can you ask Zoltan if you can jump it?
    I wonder if there's anything that could close the tolerance between the shaft and bearing. Foil tape? That translucent electrical tape they use inside computers and devices?
    What's the other source for the switch?
    Woof.
    Viking64 Posts: 7,606
    msg wrote: »
    Woof.
    HEY!
    Watch your language.
    msg Posts: 10,458
  • Hermitism
    Package arrived two days early. That was much more delicate work than soldering an IEC inlet.
    Hermitism Chapter 1
    In the beginning... the hermit said, "Let there be light!" and there was light.
    And the hermit saw the light and it sounded good, and the hermit divided the light from the darkeness.
    And the hermit called the light... "on", and the darkness he called... "off". And the music was day one.
    And the hermit completed the firmament and called it the "Hermitism Ruby Edition" Menuetto.
    And the Ruby Edition deserves a ruby red light to differentiate it from the inferior standard editions.
    Thus endith the story.
    msg Posts: 10,458
  • rooftop59
    rooftop59 Posts: 8,120
    what happened to the next five days? This creation story sucks. But I do appreciate the music!
    Game Room 5.1.4:
    Bedroom 2.1
  • Hermitism
    rooftop59 wrote: »
    The hermit took the next five days off to listen to the music and give my solder joints a workout.
  • CottageChz
    What speakers does the hermit run with his Menuetto?
  • Hermitism
    LSiM703s and a Marantz NA8005 as a source for playing flac.
