One can dream, can't they? - Audio Exotics
1567810
    treitz3 Posts: 20,106
    Esoteric suite with PMC TOTL loudspeakers.
    https://www.mcintoshlabs.com/products/amplifiers/MC21KW
    If you are a McIntosh fan and have a spare 6 figures, here ya' go. It reportedly only needs 6 power cords and 4 XLR's to hook it up. Chump change, after you get the amps.
    nooshinjohn Posts: 25,995
    treitz3 wrote: »
    I bet these would take my L800's to the next level...
    audioluvr Posts: 5,986
    treitz3 wrote: »
    Meh... Pretty sure you are at that level already.
    Let's be real. Nowhere even close. This is for the rich.
  • daddyjt
    daddyjt Posts: 3,137
    ― Aleksandr Solzhenitsyn
    pitdogg2 Posts: 27,290
    billbillw Posts: 7,769
    Needs bigger meters on the amps...
    That rack is epic!
    bcwsrt wrote: »
    Probably uses it to watch The Wiggles on TV with his kids...
    That is how an attenuator should be built!
    VR3 Posts: 29,545
    I believe they need thicker cables
    Well, its a nice start at least. Always room for mods...
    VR3 Posts: 29,545
    no doubt. I guess he could slide them inside of pool noodles and then wrap the pool noodles in tech flex.
    Needs more gold and rhodium....
  • Looks like an early generation Dalek—pre-plunger arm.
    bcwsrt wrote: »
    Somewhere there is a cable company laughing all the way to the bank.
  • skrol
    skrol Posts: 3,460
    That reminds me; Christmas is coming and I need to start working on the train garden.
    I'm guessing that one of those speaker cables cost more than my entire system.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    No cable risers? Rookie!!
    VR3 Posts: 29,545
    Is everything completely reflected sound? Or am I missing something
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,301
    edited December 2024
    The speakers are the Harold Beverage model III speakers which are electrostatic speakers with a wave guide to create an extremely wide dispersion pattern. The designer, Harold Beverage, was an audiophile who was an expert on radar and used his knowledge of radio frequency antennas to model the guide. The original speaker used an output transfomerless tube amplifier connected directly from the output tube's plate to the electrostatic stator, no transformers at all. When a tube amplifier is connected to an electrostatic speaker the output tube's high impedance is stepped down by the output transformer. Then inside the speaker the incoming signal is stepped up to provide the stators high polarizing voltage (2,000 Volts in this case). Kind of like first making tea, then using the tea to make coffee; lots of changes happen. The Beverage amplifier was designed by Roger Modjeski, a true tube expert and was located in the bottom of the speaker. The speakers were intended to be placed on the two side walls facing each other. The stereo image would be suspended in the middle, eerily suspended actually. I remember hearing a Laurindo Alemeida direct-to-disc recording on Crystal Clear records with these speakers and the guitar was right in front of me. No kidding it was there, "know what I mean, Vern?"
    The version in the photo is the model III, I believe which doesn't have the internal amplifier and can be powered externally. If anyone is interested there's a pair for sale in Baltimore:
    https://www.facebook.com/marketplace/item/938120197677000?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp:6784a4f4-8baf-4214-8800-1fbc33cd80a6
    VR3 Posts: 29,545
    Very cool, would be a fun demo!
    I wouldn't mind hearing those, with the internal amp. Interesting design.
