Parasound 2205AT died…replacing with a Rotel RMB-1585. Thoughts?
Ethancf
in Electronics
My Parasound served me since 1997 and it finally gave up. I still might get it repaired, but in the meantime, I ordered a Rotel RMB-1585 to power my Polk LSi system.
Did I make a mistake or is this a worthy change?
Thanks,
Jason
Thanks,
Jason
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Answers
Worthy. I consider them to be equivalent in function although designs are different. Rotel makes good amps since they got off the Class D bandwagon. The main difference is the Rotel MKII version uses two transformers and smaller heat sinks than the Parasound product. It appears the Rotel uses four internal cooling fans to make up the different cooling potential.
It's likely the Parasound amp is biased slightly more in Class A but I don't see any published evidence of that. Not an issue in real world use. Power output from the Rotel is slightly less capable but again not a real world use issue.
The other obvious option would have been a Parasound Halo A51. Personally, I would have carefully considered the A52+ with LSi speakers above the Rotel amp. That has more than enough high current output for those speakers.
They both weight above 80 lbs. -
^^^ man, always such great info.
Timely post - my 2205 went T.U. two weeks ago. I'm pretty sure it's just the power switch or a slow start relay. I had a similar thing happen with a sub a year or so ago. They both make this rattley-vibrating sound when powering on.
I disabled signatures. -
The HCA amps were fantastic and the Halo line didn't really have to change much. Casework, cosmetics, some signal path tweaks, and a few higher quality parts was all.
I just received the Rotel, and man is it a beast! I’m still dialing it in, but it’s every bit as strong as my 2205, and a bit warmer sounding.
Integrates fantastic with the LSi25’s, LSiC, and LSiFX’s.
JasonTHE SYSTEM
