Phono specific cables
What are you using? What do you like? Are they preferred over regular interconnects?
Discogs
  • tratliff
    tratliff Posts: 1,811
    I had been using a Furutech for the past 5+ years up until a week ago. I was happy with the Furutech up until I replaced all my cables in the last 18 months.
    After talking with Marvin at Southwest Audiofest about Crystal Clear Cables I gave Mel a call and he built me a Magnum Opus 2 with WBT terminators. I only have about 6 hours on it but am liking what I am hearing.
    F1nut Posts: 52,000
  • displayname
    displayname Posts: 1,236
    Thanks for the replies! I’ll check these out.
    Discogs
  • newbie308
    newbie308 Posts: 811
    @F1nut I just added a pair of the silver signature RCA-RCA to my system between the DAC and the Preamp and I like them a lot! Better than the Wireworld Eclipse 8's I was running.
    audioluvr Posts: 5,987
  • SIHAB
    SIHAB Posts: 5,599
    edited April 2024
    I've had some success with DH Labs.
    https://silversonic.com/products/phono-cables/
    Cable break-in deniers should give these a try.
  • Emlyn
    Emlyn Posts: 4,826
    edited April 2024
    My turntable came with a high quality 5 pin DIN plug silver cable to connect to the phono preamp. I haven't felt a need to replace it with something different and the connector limits options anyway. Kimber Silver Streak from phono preamp to the preamp. Short run to avoid possible routing issues near power cords or other gear.
  • Joey_V
    Joey_V Posts: 8,603
    I have two, one for each vpi.
    Audioquest Jaguar on the Avenger/Lyra Etna
    Audioquest WEL on Hw40 Black/Airtight Opus 1
