l800's - breaker or fuses on board?
So here's the situation, my main tweeters in both channels aren't sounding after a most unfortunate blast of FM static, SDA tweeters sounding as normal (at least as normal as they can without the main tweeters playing the lead role.)
Are there breakers or fuses that might have been tripped in the crossover or elsewhere? There's no sound whatsoever coming from the main tweeters- unplug the interconnect cable and no sound out of any tweeters(as expected). Any advice is appreciated, I'm not even sure how to extract the crossover for diagnostics.
    nooshinjohn Posts: 25,924
    unfortunately, it sounds as though both tweeters are cooked... can you take close-up pictures of them and post them here?
    F1nut Posts: 51,768
    There are no fuses or polyswitches. You either cooked a resistor or two and/or cooked the tweeters.
    This is your crossover.
    The crossover is pretty robust, Jesse. I doubt that would be the source.
    F1nut Posts: 51,768
    5 watt resistors do not take much to cook.
  • Emlyn
    Emlyn Posts: 4,708
    Both stereo tweeters out tells me it's likely something in the crossover. Could swap one of the SDA tweeters into a stereo tweeter spot to see if that tweeter can still produce sound there.
    Are the speakers under warranty?
  • Not sure about the warranty, may depend on how nice the Polk support guys are to me. I got them new in original sealed boxes a year or two ago from an eBay reseller.
    I see no physical differences between any of the tweeters, and there is not a bit of sound- nothing, I'm thinking a blown tweeter would show at least some sonic or visible evidence. Thinking about trying your Tweeter swap advice just to be sure.. Any special method for removing the tweeters and/or getting to the crossover? I couldn't find any reference docs or disassembly videos.
  • F1nut wrote: »
    A couple of new five watt resistors.. that would be nice. Here's hoping.
    F1nut Posts: 51,768
    Nope
  • Spot on guys, swapped the mains/sdas, it's definitely the tweeters. Now to find replacements... do you think Polk offer warranty replacement in my situation? if not, is it possible to order them from the parts department?
    Contact Polk CS and let them know you have isolated your issue to the tweeters. They will send replacements. but have your proof of purchase at the ready when you call.
  • SDAddiction
    SDAddiction Posts: 5
    edited April 2024
    Probably a long shot with my rudimentary soldering experience but I'd also take a crack at repairing these if it's remotely possible.
    Will do, thanks!
    F1nut Posts: 51,768
    Forget about fixing them. In addition, you can't expect damage caused by your hand to be covered under warranty. Now, Polk may cover them, but you shouldn't expect it.
