M11T Mod Question
My friend picked up a pair of M11T's and asked me to go through them.
Already have all the Sonicaps and the crossover stuff to do the TL mod.
Have the RD0-198's and bezels from @xschop .
Hurricane nuts throughout (of course).
Picked up Sonic Barrier 3/4" 3-Layer to go behind the 6510's.
Question is what dimensions should the Sonic Barrier be cut to, and how much of the original Dacron should be removed to compensate for it?
Thanks.
"Pride is concerned with who is right. Humility is concerned with what is right."
-Ezra Taft Benson
    Toolfan66 Posts: 17,999
    Don’t remove any Dacron, and between a 4” X 4” - 5” X 5” Square behind each driver is plenty. I don’t remember where cabinet bracing is in the 11T’s, so it may very a little for your application..
  • Gardenstater
    Gardenstater Posts: 4,769
    edited March 2024
    It needs to be cut into the shape of a 4 leafed clover and have an area of 25 sq. in. and align the petals of the shamrock with the windows of the Midwoofer.
    Ha. Just kidding. Sort of. I think experimentation is definitely warranted.
    The volume taken up by the foam underneath the vinyl layer would tend to offset the effect of the absorptive foam above, with respect to effective cabinet volume.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • joebass3
    joebass3 Posts: 311
    I used a 4x4 square behind the drivers in my Monitor 7's and 10's but opted for the 1-1/4" thick Sonic Barrier.
  • Gardenstater
    edited March 2024
    I used 6" x 6" BH5 (which is thicker than 3/4") in my 7Bs and there is definitely not any life sucked out of the music. Bass is very impactful still. Midrange vocal clarity was improved noticeably, as in hearing the vocalist take a breath etc.. I aligned it with the sides parallel to the cabinet but contemplated doing it 45deg to that.
    I didn't remove any dacron. BH5 is neutral in its effect upon effective cabinet volume because of the volume underneath the vinyl. I wouldn't remove any Dacron in your case either.
    Another factor, that doesn't exist in your case, is that BH5 has the panel vibration dampening base layer.
    "If" what Danny Richie says is true, namely that the floating vinyl layer with foam underneath it can mass load the driver cones which would introduce distortion potentially, then there would be very negative effects resulting in using too much of the stuff that has that vinyl layer.
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited March 2024
    The RTA 11t has very close to twice the internal enclosure volume of my 7Bs. Mr. Spock says 99.4% more. It also has a deeper enclosure at 14-3/8" vs. only 9-1/4".
    Any internal bracing would throw off Spock's calculation.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,700
    A 3x3 or 4x4 inch square of the original BH5 is way more than enough behind a Polk mid-driver.
  • MrGeology
    MrGeology Posts: 86
    Thanks everyone.
    Since we don't have BH5 will try going with ~ 5x5 squares of the 3/4 Sonic Barrier behind the drivers.
    With the dacron in there (the way it was originally) the Sonic Barrier will not be directly exposed to the drivers (dacron will cover the Sonic Barrier), which I am only guessing is fine as no one has addressed this issue.
    -Ezra Taft Benson
  • bcwsrt
    bcwsrt Posts: 2,388
    That’s been discussed. Yes, the dacron goes back in its original place.
    If the Sonic Barrier is anywhere near as potent as BH5, 5x5 squares seems like a lot.
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
    bcwsrt wrote: »
    Sonic Barrier is not like the original BH5, 5 x 5 squares will be fine IMO, I definitely wouldn't go above that..
    MrGeology wrote: »
    Thanks everyone.
    Correct, it will cover the SB, and no issues..
  • MrGeology
    MrGeology Posts: 86
    bcwsrt wrote: »
    The issue I stated had not been discussed.
    Toolfan66 wrote: »
    Until here.
    -Ezra Taft Benson
