Polk RT25 tweeter replacement - Compatibility between SL5505 and SL5507.
Hello people,
My right speaker tweeter went bad and I have some store selling the SL5505 near me, it's identical but the one I have inside the speakers is the 5507, are they interchangeable?
Thanks a lot!
Thanks a lot!
Best Answer
His response:
"Should be fine. The SL5507 was used in the in wall AB705 center channel speaker."
Answers
I'll check with a friend at Polk.
SeleniumFalcon wrote: »His response:
Awesome! So I can buy the sl5505 and have no differences to the other one I suppose. Thank you SO much!
