What do I have?
Bought what I was told were Polk SDA 1C's that were supposedly original except for one tweeter being replaced. I was extremely happy with the pair I received. I have been a member here for quite some time. Although they sound good my plan was to rebuild the crossovers ASAP. I removed the first radiator to take inventory and what I saw didn't match the schematic for a SDA 1C. I remove the speakers and found each had a SDA SRS2 label.
  • Unknown
    edited February 2024
  • Gardenstater
    Gardenstater Posts: 4,944
    That top tweeter "looks" like a SL2000 that someone painted black. Pretty low resolution photos so hard to zoom in and see what's what. That one driver looks like an MW6503 which was indeed used as the stereo driver in the SDA2B (the SDA driver was MW6511, MW6510, and MW6501 depending upon 2B, 2A, or 2). The 1C is supposed to have 2 x MW6511 stereo drivers and 2 x MW6510 SDA drivers.
    What are the other drivers in your speakers? You only showed us the one. Is there anything else you see that you think is wrong or is it just that one driver?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 52,406
    Those are 1B's with some sort of messed up tweeter.
    VR3 Posts: 29,751
    The srs 2 and 1c crossover are the same basically if I recall correctly, very minor differences if any
    VR3 Posts: 29,751
    Yep main difference is the sda inductor
    VR3 Posts: 29,751
    Agreed, we successfully converted a 86 srs 2 to an 87 with great results
  • Gardenstater
    Yep. I agree must be a SDA1B as others have said. And MW6509 (not MW6503). Looking at the pictures in the SDA Handbook, the driver spacings are different in the 1B vs 1C and the bottom panels are different. That's a 4 ohm impedance speaker so make sure you have good amplification that is compatible.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • irishjim
    Thank you to each and everyone of you that helped me recognize that these were in fact SDA 1B's. I acquired all of the parts to rebuild the crossovers and have in fact rebuilt the portion of the rebuild for the MW6509 drivers and MW6509 SDA drivers. I haven't acquired the Tweeter replacements yet and have held off on rebuilding that portion of the crossover. The diver portion sounds great. My dilemma is since my original tweeters test OK and sound very good. Is there a sound advantage to rebuilding the tweeter portion at this time. Film caps seldom degrade over time and the 750Pf's likewise continue to read as new. I have the parts but wasn't sure I had much to gain until I acquire new tweeters?
  • rebelsoul
    Rebuild crossovers there's a big difference
  • Gardenstater
    Not all "film caps" are created equal. Polyester (mylar) caps are smaller and have higher dissipation factor and dielectric constant than polypropylene caps. Polk used the mylar ones in the high frequency crossover circuit.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,406
    Order the RD0194-1 tweeters today. Then order the rest of the caps and resistors. Do not use Dayton, Bennic or Solen caps. Vishay-Mills resistors are a good choice.
