another r15 q- rubber feet?
edited March 2005 in Speakers
I notice that Polk sends four stick-on rubber feet with the R15's (for each speaker). Do you recommend that I use these? My R15's are sitting on a flat, hard surface (my work desk). I don't really turn them up loud enough for them to rattle or anything, but I was just wondering if you guys thought it would be beneficial to use the feet. Thanks!
Noah
Ludicrous gibs!
Post edited by nadams on
Welcome!
    edited March 2005
    I'd use them. If anything, you'll be less likely to scruff up the bottoms on the 15's.
    edited March 2005
    Good thought. I stuck 'em on. I was afraid they might pull the finish off the wood if they were to come off, but it seems that the glue is not that sticky anyway.
    Thanks!
    Noah
    Ludicrous gibs!
    edited March 2005
    Oh no, its very sticky.. like contact cement once applied and it will pull the finish off, But only if you remove the feet... they usually dont come off by them selves...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    edited March 2005
    I wouldnt stick them things on my speakers ever again...
    Just put them under it, dont put the sticky on it...
    Stuff rips the finish right off...
    ugh...
    edited March 2005
    There's no way to put them under it without sticking them to it... guess I could've stuck a square of paper over the sticky part or something.
    Oh well.... too late now!
    My fear is if they get pulled off when I'm moving the speakers some time, but I'll just try to be careful :)
    Ludicrous gibs!
    edited March 2005
    I've had them on a pair of my RT25i for more than 2 years, moved them 3 times. They have not shown the slightest sign of coming loose.
    I wouldn't worry about them for the time being.
    If you ever decide to take them off, carefully use a flat razor blade to remove them and use a mild solvent and/or friction to remove the rest of the adhesive. It will probably leave a dull spot, but its the bottom, not really noticable.
    edited March 2005
    Eh, hope I didn't give you bad advice. Don't worry about them ever coming off, though. I had my 15's for over a year with the rubber feet on and they never came close to getting loose.
    edited March 2005
    If I had to do it over again...
    I would have used Rubber bands...
    does the same thing pretty much and dosnt eff with the finish...
    Polk should really find an alternative to that...
    maybe screw on feet or something...
    edited March 2005
    But then again... as I've been reminded of multiple times before... these are only $50 speakers, right?
    Ludicrous gibs!
    edited March 2005
    Yes...
    But if I'm not mistaken, these rubber feet are included with ALL of their bookshelfs, from bottom to top (LSi, RTi, Monitor, etc)...
    Imagine putting those feet on the LSi and ripping off the painted finish...
    ugh
Welcome!
Welcome!
