Atrium 4 Speaker Mounts
ephman86
ephman86 Posts: 1
edited August 2023 in Speakers
I moved these speakers cross country but lost the Speedlock Mounting Brackets in the process. The speakers are still great but I would really like a better mounting system than placing them on a shelf. I have searched the obvious places online but I am sure there must be something I am missing or an alternative bracket.
  • Windschief
    Hi, found this threat looking for the same thing (bought a pair off ebay and there were no brackets)
    Did you find something?
    cheers
  • PSOVLSK
    PSOVLSK Posts: 5,422
    I might be able to help you. I think my old ones are Atrium 6 though, most likely not the same size. Plus, not positive I still have them.
  • Windschief
    Windschief Posts: 2
    edited February 2024
    Hey thank you for the offer- but yes the Atrium 6 are slightly bigger than the 4 :-(
    cheers
    p.s. I might not need any after all, I bought two pairs, one pair came with the brackets, and I just noticed that on this one the tweeters are dead!
