Wall mounting ES15 above ear level
rmjb
rmjb Posts: 1
I'm looking to upgrade a pair of bookshelf speakers for my living room and the ES15 is on my very short list.
The current speakers are wall mounted using side clamping brackets at about 6 ft and tilted down and toed in slightly, however I wont be able to use that for the new speakers since it will likely encounter an obstruction.
I know the ES15 has a wall mount keyhole slot. If I mount the ES15 speakers around that height directly onto the wall, will the music just go over our heads? Or will it open up and fill the room?
