I'm looking for advice on a Polk ES10 ceiling mount
Hi everyone: can anyone tell me a ceiling mount suitable for the Polk es10 without piercing the speakers? Thank you!
    F1nut Posts: 51,713
    Those are NOT ceiling speakers.
  • I know very well that they were not born as ceiling speakers, but that doesn't mean you can't put them on the ceiling as atmos speakers without having to use in-wall speakers
  • @F1nut Suggestions for atmos speakers with relative support suitable for hanging them in the ceiling?
  • There are several companies that make aftermarket speaker mounting brackets, while most are designed for wall mounting some can be used for ceiling. If it were me I would consider the type that used a speaker mounting plate that gets attached to the cabinet as the most secure. The other type that uses arms that grip the sides would always worry me. A good source of information would be an audio dealer who does custom audio/video installation.
  • rooftop59
    rooftop59 Posts: 8,121
    Buy these: https://www.ebay.com/itm/364741432244
    And these: https://www.amazon.com/dp/B0B21BNW7Y
    I have them mounted on the ceiling and aimed at the listening position. Atmos speakers don't need to be the same brand…
    Game Room 5.1.4:
    Bedroom 2.1
  • JCL
    JCL Posts: 169
    I used these brackets with the equivalent of blue tac between the speaker the base and the clamp. I tried using the 1/4 - 20 mounting screw with a different mount and did not think it would hold well. These only tilt about 6-9 degrees, but for my setup they work fine for elevation speakers.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • Thank you all so much for the replies!!!
  • PSOVLSK
    PSOVLSK Posts: 5,372
    edited February 2024
    I’ve use something similar to the ones @JCL mentioned with good results. I used Velcro instead of blu tac between the speaker and the mount.
    B-Tech-BT77
  • rooftop59 wrote: »
    Thank you, I have buy all this from Amazon Belgium, I will receive tomorrow in Italy. Bye 😊
  • rooftop59
    Itanium wrote: »
    rooftop59 wrote: »
    Let us know how you like the improvement!
    Game Room 5.1.4:
    Bedroom 2.1
    F1nut Posts: 51,713
    So, not ceiling speakers just high up on the wall.
  • rooftop59
    I have a two story house. There is no reasonable (cost-efficient) way to retrofit in-ceiling speakers. But I wanted down-firing atmos height speakers. I found this to be the best option, and it's sounds pretty dang awesome. Come on over, I'll grill you a killer skirt steak and we'll enjoy a demo!
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    In-ceiling are typically infinite baffle, but the sound the hits your ears isn't much different for atmos heights. So in that case, it's mostly aesthetic imho...
    Game Room 5.1.4:
    Bedroom 2.1
