Repairing small tear in rubber driver surround Monitor 10
redsled
redsled Posts: 21
edited February 2024 in Vintage Speakers
I recently purchased a pair of Monitor 10's for very cheap because of a small 3-4mm long tear in the rubber surround of one of the 6" drivers. I was surprised that when I gently pushed on the radiator with both thumbs that both drivers still moved just like the speaker with no crack in the driver.
Does anyone have experience repairing this ? What's best to use.. rubber cement, black silicone, or ?
  • I've never done it so I would say to ask simplyspeakers what they would recommend
    https://www.simplyspeakers.com/speaker-repair-parts.html
    If I had to wing it I would use a thin rubber adhesive like the stuff that comes in bicycle tube repair kits and apply it to the inside with a small rectangular piece of lightweight silk for reinforcement.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • lawdogg
    lawdogg Posts: 469
    You can find the right size rubber surrounds on eBay, I've used them a few times to replace torn surrounds. I'm forgetting the specific listing but you can find them using the right measurements. They are cheap.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • If you go the repair route, use a vulcanizing type.
    Bicycle tube repair kits typically have the type you need.
    Polk SDA SRS 2A
    Aragon 8008X3
    Aragon Soundstage
    Multiple Digital Sources
  • jdjohn
    jdjohn Posts: 3,375
    They are made of 'butyl rubber', so you can search on that.
  • Thanks everyone for your input. Much appreciated !
  • JayMX
    JayMX Posts: 457
    Shoe Goo works wonders. Bonds and stays flexible. Apply to the backside of the surround. Good luck!
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
    Toolfan66 Posts: 18,140
    DO NOT USE SILICONE!!!! B)
