Repairing small tear in rubber driver surround Monitor 10
redsled
I recently purchased a pair of Monitor 10's for very cheap because of a small 3-4mm long tear in the rubber surround of one of the 6" drivers. I was surprised that when I gently pushed on the radiator with both thumbs that both drivers still moved just like the speaker with no crack in the driver.
Does anyone have experience repairing this ? What's best to use.. rubber cement, black silicone, or ?
I've never done it so I would say to ask simplyspeakers what they would recommend
https://www.simplyspeakers.com/speaker-repair-parts.html
If I had to wing it I would use a thin rubber adhesive like the stuff that comes in bicycle tube repair kits and apply it to the inside with a small rectangular piece of lightweight silk for reinforcement.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
You can find the right size rubber surrounds on eBay, I've used them a few times to replace torn surrounds. I'm forgetting the specific listing but you can find them using the right measurements. They are cheap.
my 3.1TLs
I will fix your shifted magnets for free.
If you go the repair route, use a vulcanizing type.
Bicycle tube repair kits typically have the type you need.Polk SDA SRS 2A
Aragon 8008X3
Aragon Soundstage
Multiple Digital Sources -
They are made of 'butyl rubber', so you can search on that."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Thanks everyone for your input. Much appreciated !
Shoe Goo works wonders. Bonds and stays flexible. Apply to the backside of the surround. Good luck!Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
DO NOT USE SILICONE!!!!
