Heos
I'm an old **** getting into streaming a bit...just got a decent deal on a Marantz stereo 70's receiver with heos. Been running it off the tidal app on my TV...sounds pretty damn good. Would I benefit much from listening to tidal through the heos app? Keep in mind I know zip about streaming. :p
McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • rooftop59
    rooftop59 Posts: 8,120
    StevieB wrote: »
    Short answer is yes. Go through the app. It's designed for streaming audio quality, the tv is not...
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,465
    Curious, which receiver did you get? Didn't quite catch what your setup is.
  • StevieB
    StevieB Posts: 257
    msg wrote: »
    https://www.marantz.com/en-us/product/av-receivers/stereo70s
    Wanted to get into streaming but heos is not able to set this model up for some reason from my phone. I'm sure it's me not doing something right will continue to plug away.
  • StevieB
    StevieB Posts: 257
    msg wrote: »
    I was afraid that was the answer. :D
    msg Posts: 10,465
    Nice receiver! I'm not familiar with HEOS. Seems handy from what I read real quick.
  • Emlyn
    Emlyn Posts: 4,820
    Marantz/Denon updated the HEOS app last month. I've tried using the HEOS system before and always found it quite clunky from a user interface perspective. It's primarily intended to be a multiroom streaming system. Although I've owned several Marantz products the HEOS system has never been something I've wanted to keep using. It's also not compatible with all common streaming services. Tidal and Spotify should be good to go. May need to download the updated app and do firmware updates on equipment if needed. Yeah, it's more complicated than it needs to be!
    https://www.youtube.com/watch?v=NiLcExhcqoA
