Thank you all and Monitor 10As next steps
Lalala
I had another post several weeks ago and you all helped me trouble shoot and determine my issue was drivers. I’ve replaced them with ones I bought off eBay. And today, hooked them up. It sounds so much better than before. So based on what some of you said it sounds like I should work on the crossovers. And update tweeters maybe. Are there any recommended brands for the capacitors and resistors on the crossovers. I’ll post images in a comment.
Sonicap caps and Vishay-Mills resistors.Political Correctness'.........defined
