4 rti A1 + CSI A4 center + Denon AVR 710w best sound setup please
Hi... I'm trying my best to have the best surround sound for now when I'm watching a movie. I ran audysey but I still think the sound is meh ! I think the voice is way too low.
Need help I have a small open space and Denon set every thing to small except the front one... The center my avr set it a 40 MHz is that too low ?! The DB for the center is around -5.5 change it to -3.0 it was too low ... Can someone help me ... I know I need a subwoofer ... That's on my list but for now I really need better sound .. thanks
Until you get a sub you will not get the best out of your HT rig.
That said, the calibration program creates a base line. After that you need to tweak the settings manually until the rig sounds the best to your ears.Political Correctness'.........defined
President of Club Polk -
Agree with F1, a sub will make all the difference in a set up.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2
X3 on a sub, but in the meantime, all speakers should be set to large with no crossover (just watch the volume). I would also highly suggest you scour local ads for an A6 center…youncannfind one for a bill if youre patient and voices will sound much better…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
