Will the Denon AVR-4311CI be able to handle two pairs of LSI15's?
Does anyone know?
  • boston1450
    boston1450 Posts: 7,758
    Probably not. Especially being they are 4 ohm speakers & 2 pairs is very questionable
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    Randy-Maine
    by David WMG
  • boston1450
    edited January 2024
    Just curious. Why 2 pairs of tower speakers ? You could always add a external amplifier by using pre-out & bring a pair of those speakers alive by feeding them power
    Randy-Maine
    by David WMG
  • Emlyn
    Emlyn Posts: 4,786
    The LSi series speakers won't perform their best with just a receiver but they will play within reasonable volume limits. The pre-amp outputs on the receiver provide the option for adding an amplifier that can drive them to their full potential. Polk recommended high current amplification with the LSi, LSiM, and Legend lines.
    Is it just four LSi15s in the system or other speakers too? Adding more speakers would draw more current from the modest power supply in the receiver to the extent that driving the speakers at high volume could fry the tweeters. Replacements may be difficult to find.
  • boston1450 wrote: »
    They were given to me by a friend. What about the marantz ma500? There is a seller offering two of them. Would these work?
  • boston1450
    edited January 2024
    I've never used Mono block amplifiers. I'm sure someone will chime in..... What is your goal to do here ? Do you plan on running HT or 2 channel. Room size ?
    Randy-Maine
    by David WMG
  • boston1450
    edited January 2024
    ..... Opps
    Randy-Maine
    by David WMG
  • boston1450
    Randy-Maine
    by David WMG
  • rooftop59
    rooftop59 Posts: 8,120
    blueskies wrote: »
    boston1450 wrote: »
    Each one powers a single speaker. And they are pretty weak for Monoblocks. I would just run one pair, and the denon would be okay but not ideal.
    Game Room 5.1.4:
    Bedroom 2.1
  • Thanks guys. I purchased a Pioneer elite sc-05.
    Apparently this should get the job done for all 4 of them.
  • boston1450
    Congrats on your Pioneer purchase. So you are going to be using it on (4 ) Lsi15 speakers ? How will you be hooking them up may I ask. How big is your room ?
    Randy-Maine
    by David WMG
    nooshinjohn Posts: 25,955
    The Pioneer, though more capable, is still not enough to handle 4 LSI15's... You need a pair of robust two channel amps to get them to work as they should. The issue is not wattage, but rather current. They are a very demanding speaker as a pair for any receiver. Trying to run 4 of them at any level approaching theater levels may work for a short period of time, but something is bound to fail.
    txcoastal1 Posts: 13,514
    blueskies wrote: »
    Only in theater mode, if you run in stadium mode, meaning all channels driven at same frequencies then, NO not enough power. Do you have a subwoofer to take some of the weight off the receiver?
    In theater mode the rear channels only produce the frequencies of back ground effects which is overall a minimal strain on the receiver.
    Also keep in mind if using as a theater receiver it does not have the latest codecs for audio/visual reproduction currently out there.
    If using for music, not sure why you would have 4-speakers unless you have some old quadraphonic recordings, but NO you do not have enough power
    At the minimum you need a dedicated amp for 2 of the speakers if running 4 speakers at full range or you will clip that receiver….promise you that. To much clipping and you blow the speakers and/or the receiver
    I know as I owned that generation of Pioneer and the LSi series Polks
  • boston1450
    Amongst my readings it seems to damage the tweeters as well. I've never owned the 15's & I love the looks of them. I enjoyed the Lsi7's & they seem to be flexible on the Ohms even though I had them hooked to my Parasound amplifier & they sounded phenomenal
    Randy-Maine
    by David WMG
  • txcoastal1 wrote: »
    blueskies wrote: »
    Hmm...... Yes I have two svs pb1000 pro's. So I need a two channel amp for one pair and the receiver will be able to handle the other pair? And that way, I should have no problems running in stadium mode?
  • The Pioneer, though more capable, is still not enough to handle 4 LSI15's... You need a pair of robust two channel amps to get them to work as they should. The issue is not wattage, but rather current. They are a very demanding speaker as a pair for any receiver. Trying to run 4 of them at any level approaching theater levels may work for a short period of time, but something is bound to fail.
    Can I get away with a 2 channel amp and run the other pair via receiver?
    blueskies wrote: »
    Possible, given that the second pair are used as surrounds.
    blueskies wrote: »
    I posted your reply at avsforum and someone responded. Can you please respond to this.
    My eyes glaze over when people say amps "handle" speakers. :rolleyes: They also think Ohm's/Watt's Law doesn't apply and current operates independent of voltage and power [V = I x R; P = V x I].
    Both posters think 4 of these towers is an issue, which leads me to believe they incorrectly think being physically large makes them "demanding". The opposite is more often the case. Would we even be having this conversation if you had 4 bookshelf speakers? They're usually the ones that are harder to drive, due to their typically lower sensitivity.
    The above is generic advice not taking your particular situation into account. Your speakers will be high-passed, not run full range and you'll be sitting about 2m from all of them. The notion that you'll "blow the speakers and/or the receiver" is nonsense. The speakers will give you plenty of notice if they're in distress and AVR's contain multiple layers of protection circuitry that will shut the unit down if anything untoward is detected (overcurrent/low impedance; overheating).
    Your Pioneer is a stout AVR and this is reflected in it's bench test results and it's THX Select2 certification. A THX Select2 certified AVR will be able to play any commercially available program material to cinema reference level (indicated by a calibrated 0.0dBMV) in a Select2 sized room when hooked up to a satellite/sub system comprising seven speakers with a minimum sensitivity of 89dB/1W/1m and nom. impedances of 4Ω (L/C/R) and 8Ω (surrounds/rears). A Select2 room is up to 2000ft^3 in volume with a screen to seat distance of 10 - 12ft. Your 6Ω speakers in your compact layout is a walk in the park by comparison
    please reply to this posters message over at avsforum
    Your Pioneer is a stout AVR and this is reflected in it's bench test results and it's THX Select2 certification. A THX Select2 certified AVR will be able to play any commercially available program material to cinema reference level (indicated by a calibrated 0.0dBMV) in a Select2 sized room when hooked up to a satellite/sub system comprising seven speakers with a minimum sensitivity of 89dB/1W/1m and nom. impedances of 4Ω (L/C/R) and 8Ω (surrounds/rears). A Select2 room is up to 2000ft^3 in volume with a screen to seat distance of 10 - 12ft. Your 6Ω speakers in your compact layout is a walk in the park by comparison.
  • Geoff4rfc
    Geoff4rfc Posts: 2,899
    edited January 2024
    @blueskies if I may, the approach here from your last posts appear to be pressing @txcoastal1 and @nooshinjohn into a good 'ol Texas scrap with Mr AVS man, probably not the best approach.
    Lets just take a look at a couple of things, first of all, nicely done on your AVR choice, lots of power (watts).
    Also, Mr AVS man mentioned that your "6ohm" speakers would be walk in the park. Not sure if that was a typo but that kind of miscommunication could cost you big time since your LSi15's are 4ohm speakers.
    Polk specifies: "4-ohm impedance; these speakers must be powered using high-current amplification." High powered watts are cool, but high-current is what's specified here.
    I'm thinking in order to get your answers, check on high-current equipment (mentioned by nooshinjohn) and signal clipping (mentioned by txcoastal 1)
    Just an observation here, when someone gives you a response by first saying his eyes glaze and gives you a rolled eyes emoji comes across as a little arrogant, but I would bet dollars to doughnuts this guy has no experience with your speakers. The recommendations given by the two members here as far as I know DO have experience with your speakers.
    Most likely, the best approach here would be to contact these members and ask them of their personal experience with your speakers. I could be wrong, but my guess is that Mr AVS has never seen an LSi15 much less have the experience with them.
    Best-O-luck to you.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
    Viking64 Posts: 7,590
    I'm going to AVS and I'm gonna tell on you!
    https://www.youtube.com/watch?v=uuNCbPHxtXs
  • I would sell one set of LSi15's and put the money toward a good 2-ch amp for the fronts. Small bookshelfs will do just as well for HT surround duty in all but the most demanding systems (and they're not running AVR's!), and multi-channel music listening is a novelty that quickly turns into a gimmick, IMO.
    When I first built out my system, I started with matching speakers and amps all around, pushing the same 200-300W into the rear channels as into the fronts. It sounded good, but was a waste of resources. I've since added power and more capable speakers up front, and significantly scaled back the surrounds (amps and speakers), and it sounds way better all around.
    Polk LSi15 fronts, LSi7 dual centers, Linn AV5110 sides, Polk RT15i rears, Emotiva UMC-200 pre/pro, Carver M-1.0t MkII front & center amps, Parasound surround(s) amp, Crown XLS1502 & Dayton 18" sub, BenQ HT2050 projector.
  • rooftop59
    @blueskies look dude, those 15s are 4 ohm speakers that are very demanding, and yes, the 9s are also a demanding 4 ohm load, but without the extra 10 inch woofer. Do you think those power themselves? If you cross everything over at 80 and get the volume reasonable, you’ll be fine sure. But you will be missing out on a lot of what those speakers have to offer. I owned the 7s and the 9s, and the 7s are 6 ohm and are not terribly difficult to drive, so I was able to get away with using a receiver with decent results. But the 9s? All but the most powerful AVRs of yesteryear need not apply…
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59 wrote: »
    This makes sense. For reference, my rears are 5 ft away from my listening position and my fronts are 9 ft away. In your opinion, how much will I be missing out if I don't get an amplifier?
