Connect Polk Assist to Google Home
I havent used my speaker in a while and have changed my internet provider since set up so it wasnt connecting via google app. I couldnt get it to forget the wifi network so deleted the speaker from google app. Now i cant get it to be recognised at all when I try to set up. Ive restarted my phone but this hasnt helped. Is there a way to manually put the speaker into a pairing mode?
Hello,
I'll ask a friend at Polk for you. -
Here is the procedure for resetting your speaker:
Hold down the mic mute button until the unit shuts off.
1. You will have lights and a voice prompt telling you you are about to reset the unit (voice prompt didn't come up for me, but I kept holding it extra long).
2. Then it will go dark, at that point you can release the button.
