MM2104 (10") - Ported or Not Ported?
mrmsudawgs
I have a box that is about .70 cubic feet in volume. WinISD shows that this box / sub will perform better with a port. I was just wandering, does anyone use the MM2104 in a ported, small volume box (about .70 cu ft) and , if so, how does it sound? Should I just use a sealed enclosure?
Mike
Mike
Post edited by mrmsudawgs on
that small, I'd definitely go sealed. Heck, I'd go sealed anyway. WinISD isn't always completely accurate...
-Austinhttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
Polk subs will put out more db in a ported box but they sound best in a sealed.
I recommend a .66 sealed.polkaudio sound quality competitor since 2005
same as mac, i say go with sealed - stick a small amount of polyfill in it, if you like, and have at. if you had a bigger box, say 1.0 - 1.5 cubic feet, i'd invite you to try it, but small ported boxes generally are bad news.
and this is what, the third wanderer we've had here?
