R700 + Yamaha as801?
victorshoup
in Speakers
Like the title says, will the Yamaha as801 be sufficient to drive the r700s? Thanks!
I’m torn between upgrading my monitor 70s to either these or the es60s. I feel like the r700s would be a more significant upgrade, but I’m not sure if my as801 can power it.
It would be fine. The A-S801 is rated to be compatible with 4 ohm speaker loads. People tend to run into trouble thinking that a multichannel home theater receiver can drive a whole surround sound system at high volume without damaging anything. Integrated amps like the A-S801 only need to power two speakers so the internal power supply has plenty of current available for that.
