sda-srs crossover mod
Answers
  • honestaquarian
    honestaquarian Posts: 3,275
    edited September 2023
    I happen to know for a fact that at least two of the people on here whom have responded to you telling you not to do it are very experienced in designing/building crossovers and loudspeakers.
    Maybe more.
    I purchased an upgraded crossover for my SDA's from one of them.
    So I think that they would know what they are talking about when they tell you this is a bad idea.
    Of course it is clear that you will not understand until you plow ahead blindly through the wall of snow and then then find out the hard way there is something hidden in that wall of snow that you were warned repeatedly about.
  • Alasichuk
    Did you even READ my last post?
    I said that the only thing I've heard is "don't do it"
    treitz3 Posts: 20,365
    Repeat that 144 times. What you just said.....the last 3 words.
  • honestaquarian
    Yes I did and I repeat what I said above. How many people does it take to tell you that your breath stinks before you go and brush your teeth/use some mouthwash??
    If MULTIPLE EXPERIENCED PEOPLE are telling you not to do this and that it is a bad idea. Instead of ignoring them because they are telling you something that you don't want to read. Maybe you should change course a bit and instead start asking them what kind of experience they have to back their words up.
    SPECIFICALLY @WESTMASSGUY, @VR3, @F1NUT
  • honestaquarian
    Also if you pay close attention to some little details here that I am sure as a newbie you have missed. Look at how many posts are listed next to each responders handle on here. Some of them have thousands of posts. Some of them have tens of thousands of posts. If you click on their handle and look at their profiles you will see some of them have been here for well in excess of a decade.
    You just joined this month.........................
  • Gardenstater
    Have at it. Here's the link to the schematic. If you simply remove the connections for the dimensional drivers and connect them in parallel to the stereo speakers you will drastically reduce the impedance of the whole speaker assembly. This will also mess up the voicing between the MWs and the tweeters drastically requiring adjustment downward of all the tweeter resistors by trial and error and you will end up with an even lower impedance speaker which may be undriveable.
    The answer is nobody here knows how to do it without trial and error but they know it is ill advised for the reason I gave, not to mention you will have a terrible imaging speaker because of lobing interference (you can look that up) between the two vertical arrays of drivers.
    https://us.v-cdn.net/5021930/uploads/attachments/1/8/5/1/1/26684.pdf
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Alasichuk
    Now that is a reply I can work with, understand, and follow.
    I will not mess with the XO, save to NOT use the interconnect cable.
    Unless that can cause an issue?
    The rest of you GENTLEMEN can take a lesson of how to reply from Gardenstater
    I appreciate the thoroughness of your reply and effort you took to write it.
    F1nut Posts: 52,406
    Bet he still doesn't know what lobing is and I bet he researches it after reading this in an effort to not appear ignorant.
  • invalid
    invalid Posts: 1,559
    Alasichuk wrote: »
    Other tan "don't do it", no one has said anything
    That's because there is nothing else to say, you want to ruin the speakers have at it by yourself.
  • Alasichuk
    Didn't get a reply regarding running them without the interconnect hooked up.
    Is there an impedance or other issue, noting that i know that I am not getting the benefit of the Dim Array at the listening position
  • Gardenstater
    Gardenstater Posts: 4,961
    If you want to run them as a conventional stereo pair, don't connect the Interconnect Cable. The Stereo Woofers will still produce their respective channel's signal, and the Dimensional Woofers, through their sub-bass drive circuit, will produce the same stereo signal below 150 Hz. This should minimize any lobing or interference from the adjacent woofers since they're not producing any sound above 150 Hz.
    You did already get an answer to that actually ^^^
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Alasichuk
    you are right, sorry. i forgot it because of the overwhelming avalanche of garbage that i had to wade through.
    Thanks again
  • daddyjt
    daddyjt Posts: 3,265
    Alasichuk wrote: »
    Thanks again
    You came here asking for advice on how to do something stupid and without merit. Were you met with some sarcasm? Yea. Imagine going to a Ford forum and asking how to convert a ‘65 Mustang to electric. Can it be done? Yea, probably - but just because you can doesn’t mean you should. The result would be an abomination, and no one wants to be a party to that.
    You received the best advice at the outset - buy different speakers.
    ― Aleksandr Solzhenitsyn
    F1nut Posts: 52,406
    What we've got here is failure to comprehend. Some men, you just can't teach.
  • JCL
    JCL Posts: 174
    I would suggest if you really want to redesign a crossover to first get a copy of “The Loudspeaker Design Cookbook”. There is a section on crossover design (chapter 7). Read that section at a minimum and then decide if you want to still go forward or not. You are going to have to redesign the entire crossover. There is no simple way to redesign a crossover when adding multiple drivers that I am aware of and there are a lot of calculations and work involved in designing one that’s going to actually work well. It may also be expensive to build one using quality components.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • invalid
    JCL wrote: »
    I'm sure it wouldn't just be the crossover, it would probably make the passive radiator out of tune also.
  • JCL
    JCL Posts: 174
    invalid wrote: »
    JCL wrote: »
    Yea you would probably have to redesign the speaker enclosure too.
    VR3 Posts: 29,752
    Has the op considered new speakers? Asking for a friend
  • Alasichuk
    Thanks to the few who answered with reasoning; as opposed to most who just said 'do what I say because I say so'...
    I've been disappointed before, but most of you surprised me greatly
  • ChrisD06
    ChrisD06 Posts: 929
    Alasichuk wrote: »
    So now the real question: did you take the advice and just leave the interconnect out or are you actually still going to go through with modifications?
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • Alasichuk
    I have not decided whether or not to connect the speakers together.
    I have decided NOT to make any mods to the crossover.
  • Schurkey
    Schurkey Posts: 2,130
    There ARE reasonable modifications/repairs to the crossovers; mostly involving replacement of electrolytic caps that are at or beyond their service life and therefore aren't performing as intended. Upgrading resistors, and upgrading certain inductors is also recommended--but NOT to disable or re-purpose the speaker drivers.
    As I said in my previous post, NOT connecting the SDA cable is all you'd need to do otherwise.
  • Alasichuk
    I'm setting up the system now. I can't believe how active the Dim Array speakers are without the SDA connection. The sound is, as always, AWESOME. That's the way I'm gonna leave it.
    The reason for that is that critical listening by a 75 yr old with hearing aids is not important. Volume however, is.
    Thanks again
  • Schurkey
    edited October 2023
    "Dimensional drivers" are set up intentionally to also reinforce bass. Further, they'll vibrate like small bassive radiators in sympathy with the stereo drivers due to pressure waves within the cabinet. Yeah, they're gonna move a LOT.
  • Alasichuk
    You guys mentioned that I should have my caps etc refreshed. Does anyone do this for people? I'd get that done .
  • Astrl55
    Astrl55 Posts: 68
    edited October 2023
    Contact this site's own westmassguy
  • hauxon
    hauxon Posts: 161
    You could probably achieve what you want by an external 2 way DSP crossover and change the internal wiring accordingly to disconnect the original crossover. The crossover point is around 2000 hz. Done correctly would probably result in a pretty good loudspeaker. But it won’t be a Polk SDA speaker anymore. There’s more to the crossover than the SDA crosstalk elimination. If you got one of the larger speakers the tweeter part of the crossover is quite complicated and I would not tinker with it. Even if the speakers are old they’re very well engineered even by today’s standards. What you refer to as crosstalk is exactly the opposite since it’s out of phase and thus eliminates (lowers) crosstalk for better stereo imaging. Just as your noise cancelling headphones eliminate noise by playing the surrounding noise out of phase.
    SRS 1.2 TL | SDA 2B Studio TL | NAD M51 preamp/dac | DIY SET 300B tube amplifier | Cambridge Audio Azur 851W | Chromecast Audio | RoPieee Roon Raspberry Pi endpoint
  • hauxon
    hauxon Posts: 161
    Alasichuk wrote: »
    It’s probably easiest to find a guitar amp repair man to change the caps for you. Just make sure he doesn’t use guitar amp caps! I’ve had good spell with ClarityCap ESA and CSA caps in my speakers. Avoid the cheapest caps and most will perform good.
  • Alasichuk
    What about Polystyrene caps ?
