Setup tv-soundbar-beamer-chromecast 4k
PiAir1975
I have a chromecast which i connect to both tv and beamer (using a switch).
At this moment chromecast is connected to tv. Tv and soundbar are connected using HDMI-ARC. Soundbar (Signa 4) only has 1 hdmi in/output.
Now i bought a beamer, which has no ARC support. How do I connect the beamer to the soundbar without losing audio quality. Still want to be able to hear Dolby Atmos
I'll ask a very knowledgeable friend at Polk for you.
His response:
"The Beamer cannot be connected to the soundbar if it does not have ARC. If the beamer has an analog or optical output, the connection can be made." -
OK. Thanks. I went looking for a solution. Maybe an audioextractor with arc will do the trick. Beamer has no optical etc.
