Polk r100 vs r200
I have polk r700 r400. For surround which speaker will perform best for surround sound. I am planning to build up a 5.1.4 system with denon x6700h avr. I have options for buying other brand preowned speakers like kef R3.
Answers
  • Emlyn
    Emlyn Posts: 4,871
    If it's just for home theater either model would best match with your front speakers. If you also intend to use the system for multi-channel music the R200 might be the better choice. The choice depends on space available as well. Check the measurements on the R200s. They're not small speakers.
    With a nine speaker system look into getting a separate amplifier as well at some point for best performance.
