Need some help with distortion on lsim 707
Need some troubleshooting guidance
I picked up some used lsim 707s with a lsim 706c center. I’ve been chasing a crackle issue I believe is in the midrange.
The saxophone at the start of Miles Davis “All Blue” really brings it out.
How do I proceed?
How do I tell if it is the mid driver or the tweeter?
How do I tell if it’s the speaker or the crossover?
I’m pretty sure it’s the midrange driver but I am not certain. All three speakers are doing it.
These sound glorious apart from this issue
    treitz3 Posts: 20,085
    First off, let's narrow this down a little bit more. Which speaker(s) are in question here?
  • tn2036
    tn2036 Posts: 16
    All three - left, center, and right
    Hmmm, that would lead us to take a look at all upstream gear....not the speakers themself.
    Would you be so kind as to offer us a rundown of what's hooked up in succession? From power conditioner, to pre, to source, to amp....basically the entire chain as to what leads up to the speakers.
    Knowing this will help us help you.
  • tn2036
    tn2036 Posts: 16
    That’s really a good thought
    Power:
    Wall outlet to power strip to Denon receiver and Apple TV
    Sound source:
    Apple TV 4K to denon receiver via 6’ hdmi cable (Amazon basics, have to check on the hdmi version for this cable)
    Apple Music miles Davis album, but I notice this distortion from any Apple tv content
    Denon AVR to speakers via 8 gauge copper speaker wire
    No bi amp
    No additional amplification
    I will test the same song via cd and Blu ray player
    That’s a really great idea - thank you
  • tn2036
    tn2036 Posts: 16
    Playing the cd on the Blu ray player I get the same result, so that rules out the Apple TV and the Apple TV to receiver interconnect
    I could try a different zone on the Denon to take a different internal amplifier pathway
    Keep trying the simplest path of audio to try and narrow down what the culprit is. You are on the right track. You/we will eventually find it.
  • tn2036
    tn2036 Posts: 16
    I tried a different speaker on the same setup and I still hear it in the new speaker, so that leaves AV Receiver and maybe electricity.
    Really glad it’s not the speakers but genuinely intrigued/concerned now
    Thank you for listening. Some new members reject what is requested and are stuck in their ways.
    So, the speakers are not the issue.
    Can you narrow it down to a specific component within your system?
    If you can't figure it out? The folks here sure can.
    This is what we do.
    VR3 Posts: 29,539
    those speakers are known for their tweeters, or as I call them, glass tweeters.
    Most likely break up resonance in the tweeters
    nooshinjohn Posts: 25,990
    VR3 wrote: »
    Especially if they came out of an HT setup that was pushed by an underpowered receiver or amp.
    F1nut Posts: 51,962
    You two need to improve your reading comprehension.
    F1nut Posts: 51,962
    tn2036 wrote: »
    Remove the cheap a$$ power strip.
    8 gauge wire for your speaker cable and your power source is an AVR!?! Total overkill with zero benefit.
  • "The saxophone at the start of Miles Davis “All Blue” really brings it out."
    I believe what you are hearing is not distortion caused by the sound system but it is in the recording itself. That is what a saxophone sounds like if you place the microphone too close.
  • tn2036
    tn2036 Posts: 16
    It’s the source. I hear it in wireless headphones also
    Great compliment to the sound quality of these speakers that I can hear this so clearly. I’ve listened to this album for… *ahem*… “A Number of Years” …and never noticed this.
    I’ve been chasing this for a bit. In another thread I mentioned a shouting scene in The Mummy (2017) where you can hear the mic clipping. Now I want to review the other sources where I hear this and see how widespread the source issue is. If I find one, I’ll be back!
  • Emlyn
    Emlyn Posts: 4,813
    That track is somewhat notorious for getting stereo owners to start chasing their tails looking for equipment problems after quality upgrades. :)
    I can hear the distortion on my desktop speakers. It's apparent in the high resolution mono version at 192/24 too but is faithful to the original recording. It's really more apparent in the old style stereo version in the video below where there is more separation in the soundstage.
    I must admit when I first heard it I wonderered if I had a tube going bad in a preamplifier.
    https://www.youtube.com/watch?v=-488UORrfJ0
  • Emlyn
    Emlyn Posts: 4,813
    It's one of those things that once you've heard it and realized what it is you can't unhear it. It's not uncommon for recordings of that vintage to have odd scratching and shuffling noises whether it's microphone distortion or natural movements of the musicians because the recordings are basically live captures. Dave Brubeck recordings can be similar.
    I like the mono and stereo versions of Kind of Blue about the same.
    xschop Posts: 5,369
    edited November 2023
    Most of the original recordings from this album have that close-mic distortion. One can appreciate the early recording nuances (I do), others think it's equipment playback issues, rightly so.
    This distorted sound is also heard on the original "So What" track.
