Water in Atrium 45 Speakers
markpenrose
Is there a procedure to drain the water for the Atrium 45 speakers?
I have 8 Atrium 45 I installed 5 years ago. Today, I was moving 2 units and both have water in them. I fear the other may also.
Post edited by markpenrose on
Hello markpenrose,
Welcome to Polk's forum. The grille cover can be gently pried away from the speaker's enclosure by using a putty knife around the edges. Then once the grille is removed you can take out the screws holding the midrange driver onto the front baffle. Then the water can be emptied, drying the insides with a hair drier thoroughly. You can also contact Polk's CS department and they can provide service, if you prefer.
Regards, Ken -
Kenneth Swauger wrote: »Hello markpenrose,
Regards, Ken
Thank you. That did it. Got the water out and let air dry over night then used hair dryer. Still smells a little moldy. -
Hello juliarone,
Regards, Brian
Brian -
Is there a procedure to remove bot accounts from the forum?
We have another bot account that was installed 45 minutes ago. Today, I was reading this thread and both posts have the same writing in them. I fear there may be others also. -
I believe the best course is to entice Elon musk to buy the forum- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hello juliarone,
Regards, Brian
@bcwsrt Brian, is your password "bcwsrt" or "password"?
Also, if you are selling a Marantz receiver or any Peachtree gear, put me in line.
I disabled signatures. -
I couldn't have said it better myself.
